Exercise & Fitness Logo
john Posted on Mar 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What's your problem? my life fitness 9000 hr says low voltage when I get on it. what is wrong and how do I fix it?
It works fine if until I step on and start walking on it and then it just, stops and says low voltage.
ernesto cuadra
Level 3:
Top Expert:
  • Life Fitness Master 12,223 Answers
  • Posted on Mar 10, 2012
ernesto cuadra
Life Fitness Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076370
Points
34431
Dear Sir:
Please Run the software calibration for easy diagnose and troubleshooting.
You must inpect and measure with your VOM, if the input voltage is 115-120Vac range +- 10% of tolerance if the voltage is minus 10% lower you must check your outlet wall in your hour and repair the ground and the problem call some electrician and Install stabilizer voltage. Do no use ANY power extension for your machine.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
1 Related Answer
Anonymous
  • 16 Answers
  • Posted on Feb 20, 2010
SOURCE: i need book from cardio life fitness 9000
Send an e-mail to [email protected] to request the Life Fitness 9000 manual for free.
2helpful
3answers
Low oil pressure reading
check that the oil level is not over the mark as this causes foaming of the oil and loss of pressure. At 80km/hr you will be doing around 3 grand and that will be enough to whip the excess oil into froth.. Too much oil is worse than too little oil.
Eliptical 9500 HR lifefitness lights then stos
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Start by checking your battery for the proper voltage output. The following are some helpful videos.
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
1helpful
2answers
Treadmill
Try to RUN the software calibration for troubleshooting.
However test the elevation motor, Lube THE MOTOR : shaft +gear+adjust the small POT for increase performance. see the diagram attached.
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • 0helpful
    Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
    unfortunately, is NOT possible, Not miles or kms in treadmills.
    You have to buy the eagle eye.
    God bless you
    My Life Fitness 9000 Treadmill is making a loud rattling noise when i use it which is getting louder. THe belt is fine and i cannot see any loose parts. It sounds like a grinding noise. There is a lot of...
    Could be a number of reasons - where is the black dust coming from? remove the motor hood and check for misalignment of the drive belt from motor to the front roller.
    I need book from cardio life fitness 9000
    Top Life Fitness Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Mike Cairns
    Mike Cairns
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
