*Got a new color ink cartridge. *Cleaned the cartridge on the maintenance. *If I make a copy, it copies in color. *If I print from the computer, it doesn't print in color. None of these work!
SOURCE: I have a Lexmark 5600-6600 series usb printer and
hi
you can get the Drivers of the Lexmark Printers from the Following Link
http://support.lexmark.com/index?page=home&locale=en&userlocale=EN_US
the manual as well.
take care
Tx
SOURCE: I just put a new ink cartridge in my LexMark
You just printer will not print anything, you didn't tell us if the actually goes through the motions of printing but gives a blank sheet. The fact is these two uniquely different scenarios with different solutions.
So I will endeavour to give you both solutions.
Printer goes through the motions of printing but gives a blank sheet: This is indicative of blocked nuzzles.
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a place/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Printer does not go through the motions of printing but gives a blank sheet: Usually in this case the indicator lights just blink away.
This could be as a result of either of these scenarios.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Testimonial: "I did some clean up on my computer then unplugged my printer and once I plugged it back in it started working just fine. Thank you for your response. "
SOURCE: lost the cd to run printer. Lexmark 5600-6600
here is a link to your drivers. click here
hope this helps
SOURCE: Will Lexmark 5600 work with only the black ink?
Hi there no not can work you need all the inks.
SOURCE: lexmark 5600-6600 series delete print job
when you want to delete some print jobs command try to unplug data cable first then cancel print jobs this will sure help your query
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Try to re-seat the cartridges in the printer. Open the printer
cover > remove the cartridges > close the printer cover > re-brick you
printer by pulling out the power supply - black box behind the printer where
the power cord is plugged in, and re-plug after 10 seconds. When the printer
turns on, reinsert the cartridges and close the cover. Try to print a document
again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print
cartridge nozzle. Please follow the steps below to fix print quality issues
with your model:
From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a page forcing ink through to clean the print
cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
with your model:
cartridge nozzles.
