Maytag MAH2400A Front Load Washer Logo
john twomey Posted on Mar 06, 2012
Maytag washer leaking from bottom
Mah2400aww model number
ernest wilson
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Mar 29, 2012
ernest wilson
Contributor
Level 1:
New Friend:
Answers
9
Questions
Helped
5664
Points
12
This is a fix for the Maytag MAH2400AWW, the machine kept displaying SUDS, the machine is 2-3 years old and it started doing this 4-5 months ago. I cleaned out the washer, and used HE detergent, ran it empty, to try to flush it out, used approved cleaners and ran it throught the cycle, still no good. I finally took out out a maintenance contract with BSF, the service guy came out today pulled the pump off and showed me inside it was missing half of the blades off the impeller. I remembered a year ago a coin had wedged in the pump which I took out and put back, not realising it had taken some teeth off the pump. Therefore the pump was not able to pump out the sudsy water very well which was staying inside the drum causing the suds light to come on, they installed a new pump for me, which was covered in the contract for free. Now it's working like new again.
5 Related Answers
Anonymous
  • 63 Answers
  • Posted on Nov 12, 2008
SOURCE: MAH2400AWW washer won't drain
pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
Anonymous
  • Posted on Dec 24, 2007
SOURCE: Maytag front loading washing machine
3E has something to do with the motor control. Apparently the design of this machine allows a water leak either from the water intake box or down a rubber hose which runs along with the motor wire harness. The water tracks to the harness and motor and shorts the whole mess out. a.k.a. fried motor.
pull the back plate off (3 screws) and look at the motor where the wire harness plugs into it. Notice a bunch of green stuff- that is corrosion from the electrical short circuit causing your problem. See the rust build up on the side rail below the motor (as there will be none on the side adjacent) this is indicative of a water leak.
Our machine started doing this within the first week and we had the "service" people come out and "fix" it, but it appeared they did nothing. When I opened the machine up I discovered the problem when I ohmed out the rotor contacts in the motor wire harness and found it to be open instead of the factory specs of appx 2.5 ohms.
Maytag (now Whirlpool) does not want to send me a new motor and harness because of their bad design. The machine is a sealed unit only 23 months old. Note to all...do not buy Maytag or Whirlpool. That Maytag repair man is sitting on his bum because the company does not care about their consumers and their cheaply made products (sold at high markups).
If you want pictures write me at [email protected]
Anonymous
SOURCE: Maytag washer
also in my model I found the troubleshooting guide in the bottom front kick plate. It is a plastic piece you will have to insert a screwdriver into and "pop" off. This will show you how to enter the "secret" trouble shooting codes into the front control panel. And a definition of exactly what 3E means.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Dec 03, 2008
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 22, 2009
SOURCE: maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
1helpful
Message "suds" appeared on my Magtag laundry machine
There is a panel at the bottom front of your machine. Remove the 3 - 4 screws at the bottom of the panel. Inside the panel you will find Service Codes and other useful info. It's a good place to keep them so my advice is to put them back when done with them. It is indicating "suds" because you are either using too much detergent, wrong kind of detergent (make sure it's high-efficiency detergent) or you need to clean the catch basket on the drain pump.
The owner's manual can be downloaded here:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/user-manuals/manual-downloads/Model-MAH2400AWW/3048/0153200?modelNumber=MAH2400AWW&diagramPageId=&documentId=
Hope this helps.
How to repair nd code on a maytag mah2400aww washer
Remove the back panel (2 screws). On the bottom tray is the water discharge pump. Clear any obstructions.
Where can I purchase a Y connector for a Maytag washer model#MAH2400AWW
I would guess that your local hardware shop should have them- they are quite common (the Y connector!)
Cheers,
John C
The Maytag repairman says my model number is MAH2400AWW. You tell me: No manuals found for mah2400aww manuals. What now?
Check for yourself, pull the washer out, and check the back. model numbers/serial numbers are normally tagged on the back.
5helpful
2answers
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
1helpful
2answers
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
