Hi I have bought a msi r5450 graphics card and it started out working fine, then suddenly it stopped detecting my graphics card. Everytime i go to amd.com to download drivers, i install them but after reboot it tells me i've not installed the right drivers or they are not working properly... When i go under display resolution, it wont detect my LED tv which is hooked from the HDMI in the pc to the TV... I have tried everything i know, and im lost what to do, please help me!! I have also tried uninstalling the drivers and reboot, that doesn't help any either...
Dear,
There are two points.
1. Ensure that you are downloading and installing the correct driver for your graphic card.
2. If the fist condition is fulfilled then unplug the graphic card and check the system with the built in graphic card in motherboard and install its driver and get its functionality. When you are ensured that system is working with its own built in graphics then plug it again properly and install the driver. Ensure the proper plugging of your graphic card. Sometimes improper plugging of card cause this issue.
The second step will confirm the two things. one that your motherboard is functional with its own card and the reason is extra graphic card plugged in slot.. and the 2nd is that the card itself causing the issue not the motherboard and the issue was replugging...
best of luck...feel free to ask more...
SOURCE: I got the BSOD when
Good day..!Since your using the latest socket 1155 motherboard,and u encounter that hdmi is not working,the problems was the hdmi port,so i think you better change or replace other mother board for .tnx..hope it can help you sir.
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including
electrical extensions IDE,SATA
the leads from your
"((motherboard to your hard drive))"
make sure they have a secure connection and are not faulty or just
replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd
3 1/2 inch floppy have secure connections and are not faulty even the electric
extensions or just replace them they could be faulty a computer needs its
connections to continue its cycle and have an end so any faulty leads will end
up with a computer error If your computer came with a motherboard disc the
drivers could be on it or you might have a dirty graphics card remove the
graphics card and clean the socket
