D-Link AirPlus DI-524 Wireless Router Logo
A
Anonymous Posted on Mar 06, 2012
Connecting d-link airplus xtreme g to time warner cable modem
Syzys
Level 2:
Sergeant:
  • Expert 361 Answers
  • Posted on Jun 24, 2018
Syzys
Expert
Level 2:
Sergeant:
Answers
361
Questions
0
Helped
204140
Points
853
I would suggest that you go through this guide, it will explain you every step which you need to make to get your modem and internet connection back on track:
The ultimate Link Troubleshoot guide: Problems. solutions, PDF manuals
5 Related Answers
MysteryFCM
Steven Burn
  • 187 Answers
  • Posted on May 26, 2008
SOURCE: D-Link AirPlus Xtreme G DI-624 - Setting Wireless Key
You don't need any software, no. All you need to do is login to the router (usually 192.168.2.1 or 192.168.1.1 for D-link) and configure the wireless security (including the key)).
ohms
monk3ybidzness
  • 1879 Answers
  • Posted on Jul 04, 2008
SOURCE: Firmware upgrade
Greetings,
Yes, recently the manufacturer released a firmware upgrade.
You have the option not to or just follow the on-screen instructions.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
pamthegreek
Pamela Bates
  • 149 Answers
  • Posted on Aug 28, 2008
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
costamogen99
  • Posted on Dec 03, 2008
SOURCE: what is the latest upgrade Firmware
Hi, You need to make sure you use a hard-wired connection to upgrade your router and the latest firmware can be found at http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevC#firm (This is for North American users only! If you do not reside in North America - DO NOT USE THIS).
Anonymous
  • 145 Answers
  • Posted on Mar 12, 2009
SOURCE: D Link Airplus Xtreme G network reset
First, try the username of admin and no password. If this does not work and you really did not set one then you can reset the modem back to the factory defaults by pressing the reset button on the back of the modem. Use a paper clip or similar and hold the button down for approx. 10 seconds. The admin userid (no password) should then work
Wont connect to wireless
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and access the Internet via the DSL or cable modem.
Can't get in to the router setup?
Try the http://192.168.0.1/ address in your browser, with a cable (not wireless) connected into the computer port (not the cable modem port). User is "admin" and passwd is usually left blank. Hope it helps!
Router will not connect to Modem
without more details yes however if you post the information on your system and router we may be able to help
My D-Link Xtreme G DI-624 worked quite well for 5 days -- then failed to connect with Internet while I was using it 2 nights ago. "Network Connection Disabled" was the message. Can you tell me which cables...
From modem's ethernet, connect the wire to the router's Internet/WAN port. From your PC, connect the wire to port 1 of the router. If it says network connection is disabled, right click on Local Area Connection and click on Enable.
2helpful
Airplus xtreme g doesn't work
I have have this happen before with D-Link routers. Check your ac adaptor for power. If there is power to the adaptor, then the power supply in the router is gone and needs to be replaced.
Mine blew up unexpectedly and I replaced it with a linksys.
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
D-link airplus Xtreme DWL-G650 - hang up
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
