Indesit 90cm duel fuel cooker model number kp9507eb[x]g
First you need to remove the door from the oven, Open the door fully and on the hinges you will see a little flap bit on each hinge, flip them over so they lock the hinges open.
Left the door up slightly and you will be able to remove the door.
Place the door on a soft surface handle side down and remove the screws around the edges, You will see how it is held together and be able to finish taking it apart.
When putting it back together make sure the insulating material and the rubber seals are located correctly.
Testimonial: "in the past i have had the cooker on its side, its back etc. to try and get to the hindges from inside the cooker itself. This was so easy to do. thank you very much Owen, as my wife had wanted me to buy her a new cooker. the oven door looks brand new again. RESULT. By Roy Beard."
SOURCE: Model number SI 9TF GRA Britannia Range Cooker
my larger oven on my britannia range has stopped working would it be the themostat and how much would this cost and can i fit it myself? the grill is working and so is the small oven can anyone help please. ben.
SOURCE: How to Dismantle Oven Door to Clean Glass
yep but it isn't worth it in my opinion if you want to know i can tell you its a pain and usually you cant get it all off because its baked on but if you want to do it just reply to your own message and ill write procedure in the morning there is about three or four pieces of glass in there insulation all kind of stuff lol -tech17
SOURCE: Clean Oven Door Glass
its really not worth the effort there are acout 4 different pieces of glass in there most of the times the stains are backed on and cant be gotten off the two inner pieces are about 100 usd apiece and you need to remove the door to take it appart if you deciede you still want to ill instruct just reply to this thread
SOURCE: glass on front door of
If its not too old, try sears.com
They carry many parts and if not there try apwagner.com
It is much more complicated than that. There are usually more screws once you take out the first 5. There are a total of 3 panes of glass inside the door. If you are very careful to note how the door comes apart once you've removed the screws, then you will be able to do this yourself. Just be aware that this is going to be more complicated than it looks. Lay the door on your counter or floor with the outside of the door up. Take out all the screws around the outer egde of the door. Lift by the handle and turn the top half of the door over so the handle side is on your counter. You will see 2 panes of glass held by the same bracket on each side. You only need to take one of the brackets off and remove both pieces of glass. Now you can clean the inner most piece of glass. Then clean the 2 you removed and put them back. Now reasssemble the door in the reverse steps. Make sure that all insulation and seals are back in place.
