I have checked for blockages but the water will not drain away,is the pump faulty
SOURCE: Washine Machine pump
Sounds like a pressure switch tube may be blocked or switch may be faulty. Is there a switch on your machine? If so try pulling the tube off at the bottom of the switch and blowing through it to clear the blockage. (If you take the top lid off you should see a diaphram operated switch with a small bore plastic tube going from it to the bottom of the machine)
SOURCE: hotpoint wm75 drain pump removal
soz didnt realise it was a wm75 .unplug machine and remove lower back panel.remove water and take off hoses.pump is secured by 2 phillips screws underneath.remove wiring block and after removing pump there is three t15 tox screws on pump housing. sounds like u have something obstructing pump impeller
SOURCE: Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
SOURCE: The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
