Question about Sony MHC-RX70 Shelf System
CD player problem
The CD tray opens as soon as the power is applied. The open/close button has no effect, the tray will not close with the button, however when the open/close button is pressed the disk turntable rotates but it never drives it closed. If the tray is manually pushed in it opens immediately. The disk select buttons rotate the disk tray and the exchange button rotates the tray. The CD drive never activates. The rest of the unit is working OK
  • Anonymous Mar 23, 2014
    when I push the open button it won't respond
    New Friend:
Exact same problem. I found a bad belt under the round CD holder tray. First take off the metal case sides and top (four screws). Then remove the Cd tray by refmoving the screw in the middle. If you can get the cd tray carrier to slide out then you can see the black belt that operates it. The belt on mine was completely off. I haven't replaced it yet but hoping that will fix it.
Posted on Jan 05, 2013
    Novelist:
    Champion:
  • 275 Answers
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Posted on Sep 20, 2006
  • cocco288 Aug 08, 2011
    Hi, I am having the exact same problem with my CD tray staying opened. Please let me know if you have repaired it and what the actual problem was? thank you!!
  • Pravin Gupta Aug 09, 2011
    Dear Cocco288
    Certain things cannot be done by 'everyone' with their home set of tools....
    And what 'comment' I had posted 5 years ago, still holds good. I have mentioned those areas / sections which i would check first. And I will advice you the same - get the machine checked by a professional.
    Thanks
SOURCE:
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
My dvd is not working on my blue ray it saying go to update some software
you will need to download the update from
http://pages.samsung.com/us/bluraysupport/support.html
how to - make an update CD
  1. Download the software update file for your hardware.
  2. If the update is compressed (zip file or rar file), the file should be uncompressed before burning.
  3. You must burn the update file on a blank CD-R/W disc by using "Burn Image" option.
  4. Burn an image file of the software update file (*.iso)
how to - update your player with your CD
  1. Press OPEN/CLOSE to open the disc tray.
  2. Insert the update CD-R disc with the software update, label facing up.
  3. Press OPEN/CLOSE to close the disc tray.
  4. Wait 1-2 minutes until the screen displays "Verifying Firmware version..."
  5. After checking old and new version, select "Yes" or "No" with "?" or "?"
    on the remote control. If you select "No", BD-P1200 will be powered off in a state of tray open.
  6. Press ENTER button on the remote control.
  7. Remove the update CD from the tray.
  8. Screen will display "Firmware Update Now Processing... Please do not turn off the power".
    This process will take 4-5 minutes. When done the screen and power will turn off automatically.
  9. Turn the unit on again with the power button. They tray will close automatically and a
    Menu Language Selection screen will open.
  10. Select the Language you want by pressing the corresponding number button.
  11. Update is complete.
Jan 15, 2011 | Samsung BD-P1500 Blu-Ray Player
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
SL-PD8 cd tray is opening and closing, nonstop.
I called panasonic and they told me to do a hard reset on the system it seems to have worked on mine. Hold the power button continually while you unplug and replug the unit.
Jul 26, 2009 | Technics SL-PD8 5-Disc CD Changer
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
How to change region codes from only 4 to 2 & 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (mine was 080220.13.B.1080PXKEG)
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear.
6) Now type the code that applies for your region (R4 is 76884). A '4' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
Enjoy
Apr 18, 2009 | Samsung DVD-1080P8/XEU DVD Player
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
1,028 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
