Sounds like you have either a short in your speaker wire somewhere, wires touching in the back of the unit or a short inside the stereo itself... Try pulling the radio out and unhooking all of your speakers...Turn unit back on after all speakers are disconected...If unit still shows protect, then radio is bad...If it doesnt, power off and hook up speakers one by one and power it back on till it shows protect again....When it does, the last speaker wire you hooked up has either a crossed wire or the speaker is bad...
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
protect mode should be reset if the negative of your amp is disconnected then reconnectewd. if it doesnt help, move your ground to a different location. if THIS doesnt help, consider a repair or a new amplifier.
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
Hello all I had that same problem & I went to www.kenwoodusa.com & downloaded the owners manual for our model type & problem solved...there's a reset button to the left of the number buttons & the auto button on the face....u'll have to use a pin or something to press it but it fixed my problem!! I can play cd's again!!!!! ^_^
ccc
This is on kvt819. Driving on one raining day and the next thing I heard was a strange noise from the front spearkers.
Then the display appeared on the screen since then.
The brain box was sitting in the truck of the car. It looks like water got into the unit.
I have cleaned out the unit and is well dry. Still having same issue.
Any help will be appreciated.
sdssa
