How to use the self cleaning feature I do not have the manual
SOURCE: How Do I Use Self Clean Oven Feature?
Kathy - we just figured ours out!! Hit the clean buttton, will light up With "cl n", hit 2nd time and it will start the cleaning. Ours set for 4 hrs! Good luck!! This is for the maytag performance!
SOURCE: Self Cleaning Feature
First... yes you should remove the racks before using self cleaning. Broil pan too if it is in there. Second... the doors will lock by themselves, you don't need to do anything there. typically it takes about 3 and 1/2 hours to go through the cleaning cycle and yes you can use the cooktop while it's cleaning.
SOURCE: Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
SOURCE: maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
SOURCE: How do I use the self-cleaning oven feature
An easier option for you would be to download a replacement manual. Go to managemyhome.com and register. This is a FREE service. Once registered, log in and go the "Home Manager" link at the top of the page. Look for the "Owner's Manual" link under the drop down menu and click on it. Enter your Brand Name and Model Number. Your Owner's Manual is listed in a downloadable .pdf format that you can save to your computer or print out for ready reference. I hope you find this information helpful. If you have further questions, please let me know.
