People can hear me when i speak into the mic, but i cant hear game sounds or chat and ive tried reconnecting, unplugging everything, plugging it back in, and literally everything else. its been a while since i've used them, and i also tried pressing and holding the bypass button, i have the hdmi cord plugged into my tv, and i have the AV wires plugged into my x41 transmitter, just the red and white. if you can help at all its greatly appreciated!
Can other players hear you speaking on XBOX Live chat? I'm not sure if you mean "you" can't hear yourself speaking or that "others" can't hear you speaking.
Have you tried using your X1 with a PC (green Line Out and pink Microphone jacks)? If the mic works on the PC, then you know the chat/controller cable should be replaced.
Bluetooth Headset Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
Make sure your Bluetooth headset is fully charged before you begin.
Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
Set the "Microphone Level" to 3. You can change the level any time if needed.
Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
In Game XMB:
All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
Video Walkthrough (thanks jonny k)- http://www.youtube.com/watch?v=8tSItLGLsX8
Playstation 3 Users Guide- http://manuals.playstation.net/document/en/ps3/current/index.html
All you have to do is plug in the mic, go to Accessory Settings, pick
the correct mic for input and output, and test whether the mic is
working by talking and looking at the sound level. Then when you go
online to play COD4, there should be a mic icon next to your PSN. It
should light up when you speak. There is no button to push.
Have you tried using your X1 on your PC? Plug the green plug to the green jack, pink plug to pink jack, USB plug to USB port. Speak into the mic and you should hear yourself in the headset. If you can hear yourself, then the problem is the chat-controller cable and you should get that replaced. If not, it may mean your X1 mic is broken and you should contact Turtle Beach about that --- [email protected].
You probably kinked your controller cable. That will cause the mic to malfunction. You should purchase a new controller cable on TurtleBeach's website. They are only $4.95.http://www.turtlebeach.com/products/efx1a/replacementparts.aspx
Also make sure you have the Xbox Live settings on "Play through headset"
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
