Bosch HMV9305 Microwave Oven Logo
Brian Z Posted on Mar 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intermittent heating My microwave has been heating intermittently.Sometimes it works and sometimes it doesn't.A couple of weeks ago after closing the door it kept running and had to pull the plug.
Anonymous
Level 3:
  • Bosch Master 6,771 Answers
  • Posted on Mar 06, 2012
Anonymous
Bosch Master
Level 3:
Answers
6771
Questions
0
Helped
1779151
Points
21413
From the description you have a bad latch switch on the door caused by build up of food particles or ware.
Knocking noise in Panasonic Model NN-S969BA Manufactured 1999
open it and check screws. anything that vibrates will sooner or later loosen internal screws. maybe put a locking ring on it if u find it
ManualsLib Makes it easy to find manuals online
serach here for service manual .
2helpful
Microwave oven doesn't heat.
Yes! I have come across the odd case where the magnetron was intermittent, fortuneately it is rare because this type of problem is very difficult to nail down.
NNCD997 Microwave Convection Oven
The magnetron may be intermittent or the keypad control board is the problem. My recommendation is to use it until it finally fails and go out and buy a new microwave oven, "more cost effective"
1helpful
2answers
Thermandor Microwave MBES is shutting off.
That is a possibility but there other parts that can come into play, a bad magnetron " filiment sometimes opens" high voltage diode " sometimes cracks and developes a high level short, and finally the high voltage capacitor " will normally short" I do recommend a professional in this case.
1helpful
My microwave intermittently fails to heat the food. Unit runs and lights up but does not heat up food. Microwave is 4 months old. Problem just started a few days ago. tried every combination of buttons,...
Hello there:
It sounds normal, but there's no heat When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Microwave heats intermittently
Doug, not not attempt repairs on your m/wave unless you have had training.
When you take off the cover even with the plug turned off, their is still charge inside the m/wave which could kill you!
sounds like the magnetron may be faulty, get your approved engineers to carry out a' power check' on the magnetron etc,
2answers
JVM2050 Doesn't cook food sometimes
Not the magnetron if intermittent. Probably a bad smartboard. Easy to replace if you know the basic precautions to take.
Top Bosch Microwave Ovens Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
