Battery replaced by jeweler, won't reset
SOURCE: Casio Databank 150
If your databank is like mine (DB-35H), there is a TINY spring in a really unusual spot that you probably didn't notice that fell out. Laying the watch face down and with the back off, there is a little tiny hole in the back towards one of the corners. (sorry, already put my watch back together and didn't notice which corner.) There is a tiny (1/16" x 1/4") spring that sits upright in that hole. It must make a contact with the metal cover. I replaced my battery and when I did, a spring fell out. I looked all over the internet, then wrote Casio, who said they didn't have access to the information about where the spring went. (Doh!) I got a used DB-35H from my brother and was going to swap the innards when I noticed the spring on his. Put my spring back and it beeps! If you've lost the spring, don't know if you can fake it with tinfoil or not, but it really is a TINY spring. Good luck.
SOURCE: new battery can not reset watch CASIO #2735 Atomic wave ceptor
Did you try this?:
http://world.casio.com/wat/download/en/manual/
Rate, please.
SOURCE: Cannot reset time
Hi to anyone with a wave ceptor, when you replace a battery you need to re calibrate the hands to 12 o'clock (also those with a 24 hour hand will need to be set to 24) this is called the home position, the same goes to stopwatch hands.
The hand setting settings vary wildly from watch to watch you will need to consult the manual or if you have lost it download thePDF file from casios support page, www.casio.co.uk , you will need adobe reader or a similar program that reads PDF files also you will need the module number, this can be found as a 4 figure number on the back of the watch, these instructions are easy enough to understand, i managed to set mine no problem.
Good luck!!!!
SOURCE: Casio tough solar databank Model DB-E30-1AV
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Casio watch manuals. Rate me, plz.
SOURCE: Casio DBCW150-1 Databank watch (battery change)
DONT THROW IT AWAY THAT IS A COLLECTORS ITEM... You can get it taken care of at www.casiowatchrepair.com or call them toll free 877.659.0761 and have them take care of it, the watch will be as good as new.
