SOURCE: need system bios update for Gigabyte"GA-7VKMP mobo.
Hi bhscam,
Try this it should help you out: http://www.wimsbios.com/phpBB2/topic6731.htmlut:
I hope this helps.
Thank you for using FixYa.com
Sincerely, cyyyd7
SOURCE: bios
Hello, after some search on the net i found this site:
http://www.idot.com.tw/en/downloads/
If you search for the text : ga-pcv2 on the site you get a section with the bios update link.
I have copyed here they said its for ga-pcv2 csi , ga-pcv2 dsi. so here it is:
http://www.idot.com.tw/en/downloads/MB-PC1000G1500G(GA-PCV2)/F5E_BIOS.zip
I hope it will help you.
P.S. : You can find all the drivers there too...
Best wishes, Borney.
SOURCE: need audio drivers for free
Hi
Thanks for using FixYa. You candownload free audio drivers for Gigabyte GA-8SIMLMotherboard from the link---
Gigabyte GA-8SIMLMotherboard audio drivers free download
Please do rate the solution and revertfor further assistance.
Thanks
Rylee
SOURCE: GA-8SIML will not post or boot. Removed all PCI
Firstly you check your RAM by use another RAM and then check it is working or not, after that if display is not coming then check your processor it is fitted properly or not if it have fitted and display is not coming then *********** board's winbond chip have been damaged.
Repair it from a techinician.
Regards
Ashly
Testimonial: "Constructive advice. Thanks."
