Compaq Presario 5000 PC Desktop Logo
Posted on Nov 01, 2008
Swapping a hard drive
I have a compaq presario with a bad hard drive and a emachine with a bad motherboard. Can I use the hard drive from the emachine in the Compaq and do I need to Dban it first.
  • goodtime1 Nov 01, 2008
    I did this and all the drivers installed but the "blue screen of death" popped up. It did go away after I presses a key on the keyboard. Does that mean that theres a virus or possibly the disk ic corrupt some how?
  • Anonymous Mar 13, 2014
    hard drive failure message
Anonymous
Level 1:
Scholar:
  • Contributor 32 Answers
  • Posted on Nov 01, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
32
Questions
0
Helped
5389
Points
48
 You should be able to use that Hard Drive in the Compaq. Once transferred, you might be have to download the drivers to make sure all your devices work. I would recomend that you format the drive and reinstall windows.
  • Anonymous Nov 01, 2008
      Blue Screens can be caused by  faulty memory, components running hot, power supply issues,  or even poorly written device drivers or hardware that is malfunctioning.  With windows XP, Im more leaning toward a device driver issue. A Blue Screen should have a message displayed stating an error code. Right down this error message as it might give you some info as to what the problem might stem from.
        Joe  < Data Miner >
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
1helpful
My Compaq Presario F732NR Laptop w/Vista won't Boot.
You have done an excellent job of diagnosing a MotherBoard fault. This is undoubtably the problem. Have you removed all/any cards attached too, like say the WiFi?
2helpful
3answers
COMPAQ PRESARIO S5200NX WON'T START - Press start button, led's light up for about 5 seconds - hard drive starts to spin, then led's go off and every thing shuts down. Power supply is ok (swapped power...
Hi:
Since you swapped the power supply already, and have disconnected the DVD, CD, and floppy, that leaves the hard drive and motherboard!
Look the motherboard over, and see if there are any capacitors that are bulging or leaking out on the tops.
Is the inside of the computer very dusty? Check and make sure when you power up the tower, that the cpu fan is spinning up.
Your CPU could be overheating, so removing the Heatsink fan and re applying thermal paste is an option too
If it is, try resetting the CMOS on the motherboard, or pulling the CMOS battery for a minite.
Do you get anything to display on the screen?
If you have more than one stick of memory, take out one of the sticks if possibleif possible.
Hard Drive will not boot in Compaq Presario C700
BIOS checksum errors occurs when either the BIOS chjp is faulty or most likely the BIOS battery is nearly flat and the stored info changes and doesn't match the checksum info.
Replace the battery with a new one, leave the battery out for 1/2 hour before inserting the new battery. The BIOS will be reset to the default settings, you need to configure it again eg, datr and time etc.
1helpful
Bad motherboard for Compaq S3200NX
Sorry to say but Compaq/HP uses proprietary motherboards which means without doing modifications to your case you will have to buy a board specific for your system from Compaq. Hope this helps.
2answers
Swapping hardrives between 2 compaqs
it is possible but i would have it done by a proffesional or you risk screwing it up...no offence i had a friend who completly wrecked his comp trying to do this he had to buy a whole new one
Hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
