My nokia e5 asking for connection to connect to internet very often whenever i use phone...i am sure i am not running any program which needs internet connection..it happened after i updated my phone throught nokia pc suite...help me to turn of this popup message ...really been headache.....tq
SOURCE: nokia 3230 phone software update
what service provider are you with normally if you go to www.yahoo.ca and type in the name of your phone you might see software updates
SOURCE: to connect internet
either u hav to download nokia pc suite 6.85.12 for nokia 3110c .. or bring the software..anyway!! u can also open with installing opera mini..
SOURCE: Can't able to connect Nokia 5200 with Nokia pc suite 7 to internet on my PC
it's better to use higher version of pc suite which can be dowloaded from nokia home page
SOURCE: i have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
SOURCE: my phone not connect by pc suit software
there are four solutions,
1-select offline mode
2-check the data cable
3-format your memory card(because there might be virous)
4-update your phone software using mobile internet
