The model is wfl 2451
Here is a manual.
If it's not he correct on go to the below link and search with the model number WFL2451
Link
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
SOURCE: Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
SOURCE: need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
I need the manual in English.
Sorry only just spotted that. The WFL2451 was never built to be sold in english speaking countries but i have found another similar model that the manual will be 99% correct for.
https://portal.bsh-partner.com/TCcustomB...
Well, it is that 1% that I need. In this manual there are three buttons which say "reduced ironing," rinse plus" and "quick wash." The model I have has four buttons with pictures on them and no words. I cannot tell from the pictures which one is the "quick wash" which is what I'm looking for. Thanks for your help.
