Dead battery. Can it be replace on this model? Thanks
SOURCE: Bettery replacement for Navman 510
Easy if you're comfortable opening up the receiver and working on electronics. To obtain a 'new' battery you can use Ebay, search for "navman 510 battery" and you should find some for sale. They seem to sell for about $20 including shipping. First find a good environment to work on the receiver, someplace where you can have good lighting and a good place to put parts. You may want to lay down a towel or something so you don't scratch up the receiver and also so if you drop the screws they don't bounce away from you.
First remove the SD card, then the screws from the back. After you have the screws out, slide your finger nail (NOT screwdriver) along the seam pressing inwards, the cases should separate and you should then be looking at the inside of the receiver. First, you'll have to disconnect the antenna connector. Then you'll have to remove some screws holding down the main circuit boards inside. Be careful when removing components that you don't crack the boards, they're very thin! After you have the boards out you'll be able to unplug the battery from the main board (they ran the cables under the boards so you have to remove them to get the battery out). Put the new battery in and reassemble.
Make sure to fully charge the battery before you first use it.
SOURCE: Navman Pin570 battery replacement
Undo 4 screws. 2 under GPS reciever flap and two underneath black screw caps (just pull these off).
Then slide something thing under edge and pull quite sharply. (its clipped on so you need to give it a tidy pull)
SOURCE: Update Map/Battery/USB cable
Please see this link for info on the battery:
http://www.sharc.net/gps_battery_repair.htm
Please see this link for OEM min-USB cables:
http://www.sharc.net/gps_repair_prices.htm
- Jim
