When i use my camera it shows distorted lines then it hangs, sometimes black screen only then phone freezes then need to restart the phone again, i already took it to nokia care but they didnt able to fix it, im not sure if its the camera module is the problem, and camera lens dont close ,im not sure if the graphic ic must be reheated or the camera needs replacement,i already change several firmwares to 11.05 to 25.07 to 25.08 and the latest belle still no luck,,,any suggestions ?
SOURCE: reinstall n 70 firmware
HEY BUDDY JUST REMOVE UR BATTREY AND WRITE DOWN UR PRODUCT CODE WHICH IS ON THE BACK OF PHONE ON WHITE LABEL. THEN JUST DIAL*#0000# WRIT DOWN UR PHONE SOFTWARE VERSION WHICH IS USUALLY SOMETHING LIKE THIS V.5.0737.3.0.1 THEN LOG ON TO NOKIA SITE GO TO SOFTWARE UP DATE CLICK ON CAN I DOWNLOAD ENTER UR PRODUCT CODE AND COMPARE THE VERSION. IF URS IS LESSER THAN RECOMENDED VERSION YOU DONT NEED UPDATE.
SOURCE: Blacked out nokia 5310 screen, possible reasons?
your best bet would to be get a new phone is sounds like your phone is got a dead back light or crossed wires from being dropped you need a new phone either way
SOURCE: Nokia 5800 screen freezes
I the physical keys are working then the problem is the touchpanel of ur screen & it needs to be replaced but if the physical keys are also not working then the problem is the software.
Go to a local repair shop or call Nokia.
Hope that'll help you..
Happy Holidays...
the problem is with your network ic.replacing it will fix your problems.
SOURCE: I'm using a Nokia 5233. The problem is, whenever I
In my experience this problem frequently occur when the Camera (lens)is not installed properly / not connected properly.So, before you go to repairing shop and if you can open the case the first thing you need to do is to re-install the camera (lens).Good luck.Thanks for visiting fixya
1) Turn off your phoneIf our Nokia N8 have problem such as hang or not responding or slow or stuck or have problem or frozen, then what we can do is try to restart the phone first to erase all temporary file and clean the cache. If the Nokia N8 problem still there then the last thing we can try is to do Master Reset to Factory Default Nokia N8 with safety way.
2) Hold "Volume Down + Camera Key + Menu Key" and press power button until your phone vibrates.
3) Wait until screen show properly... and welcome back!!
or try this one
How to Master Reset Nokia N8 do the Factory Default Setting?
