SOURCE: Canon MP530 - Fax Memory is Full... How do I clear?
Check your ink cartridges and fill any that may be low. I got that error because one of the cartridges (magenta) needed to be refilled. The printer was storing failure reports in its memory until they could be printed out, leaving no room to fax new documents. As soon as the ink cartridge was replaced, the reports printed and freed up the memory to send out faxes.
SOURCE: Can not clear memory on PIXMA Canon MX700
dear david
try this
) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release
the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2
times, and then release both the ON/OFF and Stop/Reset buttons.
(Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green,
starting with Alarm LED.)
4) When the Power LED lights in green (and "Service Mode Idle" is displayed on the LCD), press the Stop/Reset button 4 times.
5) Press ON/OFF, press Stop/Reset 2 times
6) Press ON/OFF. Unplug printer and plug back in. turn on and should be cleared
oke , post me back
cropp
SOURCE: On my Canon MX310, the display says
Try this step ... found it on Canon's website
Issue:
ERROR LCD: WAITING FOR REPORT
Solution:
Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX
When
[AUTO PRINT RX] is set to [OFF], incoming received faxes will be
temporarily stored to memory and transaction reports (TX, RX and
Activity) remain in memory. The default setting is [ON], which means
incoming received faxes and transaction reports will automatically
print.
The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
To set AUTO PRINT to ON, please follow these steps.
Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
CAUTION:
When this option is set ON, the fax machine will not monitor the ink
level of the ink cartridges. If ink is low or out, received faxes will
print with streaks or blank. Furthermore, once the fax is printed, it
will be deleted from memory.
