800 number only alway gets busy signals (tech support).
Just bought this Universal Remote today -- Avem R6. It picked up my Shar5p TV just fine, but I cannot get it you work with my DVD/VCR Combo: a Sanya DVW-5000. The owner's manual suggests 3 codes -- 003, 010, and 102. None of these work.
HELP!!!
Thanks!
Web
SOURCE: owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
SOURCE: DVD player problem
I had the same problem before. I found a loose rubber ring which drives the door open/close may be the cause. Use honey wax or candle wax to wax the ring will be most likely to solve the problem. The only thing is you need open the box by yourself.
SOURCE: I need to get one manual or download for free,
Please download manual from:
http://www.instructionsmanuals.com/u2/pdf/reproductor_dvd/Sanyo-DVW7000-en.pdf
Testimonial: "Thanks, checked it is downloading, but already got it from other site and downloaded yesterday after emailing to you. can i guy remote from you."
shoulda proofread...sorry....it AVEX, not Avem. (and, obviously, SHARP)
Need the programming code!
