I had this same problem. There are two possible solutions. First, you need to look underneath (use 2 people) and see if any hoses are kinked. If that is not the case then the machine is pulling in too much water during the dry cycle. I'm hooked up to a sink so I just turn the faucet down until the water is just a trickle. This works for me. If yours is attached to the wall you need to turn down the cold water tap. Its a pain in the ****, but I discovered no one can fix this machine, not even Haier's recommended service A&E. I always know more than the repairmen, very sad. Hope this helped you.
hey i have a haier_xqg50_11 , i srewed up the circuit board by mistake , had it taken out by repairman , and bougt another one to put in but repairman forgot the wiring sequence , can some help me with the wiring sequence?.....i can send pictures of wire colors and circuit board to you , just tell me how to hook it up..
Same problems here. It seems steam can not get out. I guess the valve program goes wrong, sending water in instead of sending steam out as it should be.
At least the washer part is fine...
hey i have a haier_xqg50_11 , i screwed up the circuit board by mistake , had it taken out by repairman , and bougt another one to put in but repairman forgot the wiring sequence , can some help me with the wiring sequence?.....i can send pictures of wire colors and circuit board to you , just tell me how to hook it up..
SOURCE: We have the Haier XQG50-11
make sure your drum is turning,open it quickly and see if it's turning,also make sure you have good ventilation behind the dryer,let me know what you find-mike
I also have the same problem. Cycle is hot, but clothes (also VERY hot) seem wetter at the end than when they started. This is an intermittant problem, though. Some dry cyles go just fine. But when it doesn't work, it REALLY doesn't work.
when machine is in drying cycle it only has high heat and no other heat settings
