Camera pictures have to be loaded down on disk, please
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as Picasa.
SOURCE: loss disk for the olympus fe-210 camera
You can download the Olympus Master 2.x software from the Olympus website here is the link https://emporium.olympus.com/studioMaster2/OlympusMaster.aspx
Hope that helps.
SOURCE: Olympus mem card will not copy pictures onto computer,PLEASE HELP
Not that I know of.
All cards have to be formatted before use.
SOURCE: my camera keeps turning off when i try to take a picture even whe
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
SOURCE: Olympus - SP-310 camera. Has broken LCD screen.
I Have a sp310 camera... It has a problem with optical zoom. Do you like to sell me your camera ou can you buy my camera?
