Vtech 5.8GHz Analog Cordless Phone Logo
Rosalind Samples Posted on Mar 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to prgram the vtech 5.8 dial tone to touch tone
When I dial a number my dial is rotary dial so I want the dial back to touch tone when i dial a number
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Mar 05, 2012
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428564
Points
622693
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
5 Related Answers
monotary
Roy McCallop
  • Posted on Jan 25, 2009
SOURCE: I can't dial out from my handsets
Here is something to try:
Disconnect or unplug the power supply (the small black box that is plugged into the wall outlet) wait for 30 seconds and then plug it in again. Sometimes the power supply needs to reset itself. It worked for me.
Thanks,
monotary
Anonymous
  • 208 Answers
  • Posted on Jun 22, 2009
SOURCE: Dialing out
it's not sending a signal to the phone service check your phone lines for proper connection
Anonymous
  • 14 Answers
  • Posted on Sep 09, 2009
SOURCE: no dial tone
vtech are not very good u mite need another fone
Anonymous
  • 52 Answers
  • Posted on Sep 12, 2009
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Anonymous
  • 10 Answers
  • Posted on Nov 29, 2009
SOURCE: i just need to know how to
you're screwed
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Switch rotary phone to touch tone
Enter the model of your VTech DECT 6.0 phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
The tone on my 2 portable DECT 6.0 phones was somehow changed- now every time I dial, I get the old rotary sound and I can not access any menu options. Help, I use my phone for work and need it fixed! ...
Your phone is somehow set to pulse dialling and you need to change it to tone. Instructions are given below.
Of course if you can't select menu options this will not work so please explain why the menu options are not available - what happens when you select the menu softkey?
Dial mode
The dial mode is preset to tone. If you do not have touch tone service, you need to change the setting to pulse.
To change the setting:
Press the MENU softkey when the handset is not in use.
Press or to select SETTINGS, then press the SELECT softkey.
Press or to select Dial mode, then press the SELECT softkey.
Press or to choose Tone or Pulse. Press the SET softkey to save, or press the BACK softkey to exit to the previous menu.
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
4helpful
No dial tone
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Dialing
Use the following steps:
1. Press the program button on the handset.
2. Use the up/down arrow keys until you see dial mode.
3. Press the select button and use the up/down arrow keys to change it to pulse.
4. Press the select button. You will hear the phone beep which indicates it has been changed.
Dialing sounds like rotary and will not allow extension choices
Since you neglected to specify the model of your VTech 5.8GHz phone I can only suggest you enter it into the search box here to download a copy of the manual to see how to switch from pulse to tone dialing.
6helpful
4answers
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
