Brother DCP 115C All-In-One InkJet Printer Logo
Posted on Apr 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get Brother dcp-115c absorptions pads? How to fit them & reset the process?
The Support of Brother Printers informed me that 'Unable to clean - fault 46' mean that the Absorption pads need to be replaced. Can you tell me where I can purchase replacement absorption pads for the Brother DCP-115C printer & how to access them on the printer? Also, I was told that there is a reset process after replacing the pads, else the machine would not work. The cost by one of their sponsored engineers is 2.5 times the price of the 14 months old machine. ICan you please help me as the machine is useless at this point and only be used about 12 times. Thanks, R. Forde
  • wilsongaz Jan 14, 2009
    What a con!! My dcp-115c is 18 months old and the call out charge to fix the same problem is £99 plus cost of parts - the printer cost me £40. What a rip off - why is equipment such as this designed to fail? We should be looking to extend the life of this type of machine and not just throw it away and buy a new one - although that is probably what brother and other manufacturers want. Irresponsible is what I call it. They either sting you with ridiculously expensive replacement cartridges or they build in a limited shelf life.
Ubaid abid
Level 2:
Guru:
  • Expert 164 Answers
  • Posted on Apr 16, 2019
Ubaid abid
Expert
Level 2:
Guru:
Answers
164
Questions
0
Helped
123057
Points
609
Right side of hean remove upper cover
DCP 185C ERROR 50
Sir/Madam
I Suggest You To Watch Clear Error 46 Unable to Clean on Brother Printers Without Number Pad To Fix Your Brother Printer Issue,In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
1helpful
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
2helpful
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
4helpful
Printer unable to clean
the printer has a counter for the supposed amount of ink the absorber pad can absorb.
i have reset the counter using the following and now it works. In theory you need to get a replacement pad but i haven't been able to find one yet. My printer is now working fine
following is the solution to reset the counter for the old fault
> Brother DCP110c Reset Counter
> 1. unplug at side of unit, switch on while pressin menu2. Enter 8 press
> set enter 0 press set
> " by using the up arrow key & SET keys."
> 3. press the mono start key several times untill the purge count appears
> on the LCD.
> 4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the
> purge count to zero (like in 1)
> 5. press the stop/exit key to return to the initial stage of the
> maintanance mode.
> 6. enter 9 twice by using the up arrow & set key’s to exit from
> maintenance mode
Michael
Unable to clean problem
turn the rpitner of then check there is not any paper jam.
also refix crtridge after clean it.
3helpful
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
2helpful
Brother DCP-115C unable to clean
you need a new waist ink absorber box from a service partner which can be found at brother homepage of you country.
After replacing the box you have to do a reset.
search error 46 or unable to clean here in the forum. it has been written many times.
Norman Weimar
Norman Weimar
k24674
