I can send faxes just fine, the printer is connected via WiFi - and I can receive faxes on the s405 just fine on the printer. But what I'd like to have is the following: when receiving a fax, I'd like it to go through the driver on the Mac and through the receive options - instead of being picked up by the s405 first. I tried setting the auto-answer to 9 rings, and also to manual - but the mac just doesn't know about an incoming fax call to pick-up. Any thoughts are welcome!
SOURCE: Need driver for lexmark z640 compatible with MAC OS X 10.4.10
go to www.lexmark.com click on drivers and downloads then click on OS compatibility lists. Click on MAC OS X and then click on home or small office/home office. This will take you to a complete list of compatible drivers for the MAC OS X for all of lexmarks printers. If it does not appear then there are no MAC OS drivers. Which I looked at for you and they do not have any. But you will see a list for the printers that they do have them for.
SOURCE: lexmark x4250 mac driver
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
SOURCE: Running Mac OSX 10.5.6 how do I get a driver for Lexmark z515?
Go to: http://downloads.lexmark.com/perl/downloads/downloads.cgi
And select your printer model and OS model. If it doesn't have 10.5.6 specifically listed, select the newest driver and try that. It should be compatible.
SOURCE: Hi I used the link that you provided and entered
Choose the XP drivers, they should still work if Vista ones are not available. If they do not, then Lexmark will not be making drivers forward for that model of printer and it'll be time to go get a new inexpensive inkjet.
SOURCE: Lexmark 2600 scanning to MAC-no can do
Edward, I have this same problem. Were you able to solve it? Anyone, can you help? I have installed the drivers. When I connect the printer to my Mac, it launches ImageCapture and previews the scan fine. But I am unable to get the "scan" button to become active, adn there is no place to save the scan. If I click "save pdf to iphoto" it saves a pdf of the entire screen, rather than just the photo. Appears not to be Mac compatible for scanning purposes. Thank you for your help.
