hi, go into menu and find delete all, this will delete all photos and videos, you can also type Kodak pixpro fz41 manual in google and download the manual, don't forget you can also bye a new memory card try and get one with a bigger memory than the one in the camera, hope this helps you.
I had a quick look at the manual and on page 8 it states:-
If icon red F appears on the screen, this is an indication that the internal memory is full. No further photos can be taken until the existing photos have been downloaded and cleared from the camera memory.
You need to empty the camera's internal memory (Download the manual) or insert an SD card, this camera can take up to a 2Gb standard SD card. Needs to be formatted with FAT 16 file system. (User manual)
You can clear ALL pictures from the card by formatting it. In fact, the memory card should be formatted EVERY time you finish downloading pictures from it. This will prevent later problems.
To format the card in the L20, press the MENU button, select Setup (the wrench icon), then select "Format card" (the memory card icon).
You can view/download the user guide at
http://support.en.kodak.com/app/answers/detail/a_id/18741/selected/true
If you have enough room on the memory card, you can copy the pictures from the internal memory onto the card and then download them to your computer all at one time. If you don't have enough room on the card, you can download the pictures on them to your computer, then clear the card by formatting it, and then copy the pictures from the internal memory to the card for downloading.
If you just want to copy pictures between the internal memory and the memory card, here's the appropriate page from the user guide referenced above: http://resources.kodak.com/support/shtml/en/manuals/urg00649/urg00649c3s7.shtml
Formatting clears the memory. If you can scroll through the menu on the camera and see a formatting button, that should clear it. Also, if you go to the Fuji website, you'll probably be able to find and download the owners manual.
Hi, Transfer all pictures in memory card to computer, disconnect camera form computer, press Menu/ Home and go to memory stick option, select Format to delete all pictures at once and will refresh memory card. You can delete pictures one by one through Delete button on camera.
Regarding supplied software with camera (picbridge or picture motion browser) please click Cancel when it prompts up when camera get connected with computer and click My Computer, click any new hard drive letter that might show as mass storage or similar word (this is memory card storage) and click its folders to copy/ cut the pictures and paste these files in computer. Hope this info will help you. Thanks.
Solution 1: Set to save the files into SD card rather than into Phone memory. For example, set song folder and picture folder to a location on memory card. Refer to the phone manual for detailed steps.
Solution 2: use a computer and card reader to manually store songs into SD card. Then set the phone to folder into sd card to get the songs. Clear phone memory afterward.
As long as there is space on your memory card you can continue to take pictures. But once your card is full you need to download them onto your computer and clear your memory card so that you have room for more photos.
Hey hardygurl198, What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps! http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf Sincerely, Allan Go Ahead. Use Us.
