Xerox DocuPrint M750 InkJet Printer Logo
Anonymous Posted on Mar 04, 2012
I NEED A DOWNLOAD DRIVER FOR MY XEROX M750 PRINTER FOR WINDOWS 7
John Watson
Level 1:
Habit-Forming:
New Friend:
  • Contributor 19 Answers
  • Posted on Aug 22, 2018
John Watson
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
19
Questions
0
Helped
9922
Points
99
I think a DVD was provied to you when you purchased your xerox printer you can also download the latest compaitable software from xerox printer website.if you want any help regarding xerox printer just call on xerox printer support phone number by dialing +61-1800-431-295
https://www.printersupportcentre.com/xerox-printer-support.html
Anonymous
Level 3:
  • Xerox Master 32,281 Answers
  • Posted on Mar 05, 2012
Anonymous
Xerox Master
Level 3:
Answers
32281
Questions
Helped
7905978
Points
102259
You maybe able to download a Windows 7 printer driver from the Xerox WEB site. If there isn't a Windows 7 printer driver then Xerox considers this printer too old and you need to purchase a later model.
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.support.xerox.com/support/enus.html
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Dec 31, 2007
SOURCE: XEROX DOCUPRINT M750
From what I have found out asking around. Go to the Xerox.com web site.
From the tool bar select Support and Drivers. In the search area, enter M750, your printer model.
Then select drivers and downloads.
Once again the drivers and download link.And select the Windows 2000 driver. I have been told that driver should work fine with XP also.
I do not have that particular model to check this out. But I am pretty sure that it should be fine, unless you have a 64 bit version of XP.
Give that a try, I am pretty sure it will work. And if you can, please let me know.
A
Anonymous
  • Posted on Jan 28, 2008
SOURCE: can't print when there's only black ink
Here's a trick that worked for me - there are two tiny prisms on the back of each ink cartridge, to refelct light to a sensor indicating whether there is or is not ink in the cartridge. Simply put a small piece of masking tape over the non-mirrored prism, i.e. right next to the mirrored prisms, to make the printer think the cartridge is full of ink. Put the small pieces of tape on each of the three empty color cartridges, being careful not to cover up the mirrored pieces, as light relected from these indicates that there is a cartridge in the slot. The printer will run as if it has full black and color cartridges, but set your defaults to only print black.
Bob B
  • 272 Answers
  • Posted on May 26, 2009
SOURCE: Need printer driver for Windows Vista
It' also listed at Microsoft as incompatable with vista. Best you can do is get a cheap old used machine that runs XP and set it up as a print server for your network, (set it up with printer sharing) send all of your documents thru it for printing. Sorry it's probably not the answer you were looking for but it is the only solution I've found for mine. I bought an old P3 machine running XP for $5.00 at a garage sale and it's working great as a print server.
Anonymous
  • 5 Answers
  • Posted on Jun 22, 2010
SOURCE: need xerox phaser 3124 printer driver compatible for mac 10.6
go to www.samsung.com download and install mac driver for ML-2510 works like a charm for xerox phaser 3124
duane_wong
Duane Wong
  • 6826 Answers
  • Posted on Jul 14, 2010
SOURCE: The Windows 7 mini drivers for the Xerox 7132 only
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=WC7132&ripId=&Xtype=download
The above is the XP Vista drivers for the 7132.
The 7232 is a totally different machine and the windows 7 drivers for it will not work with your 7131 according to their table.
Also, according to Xerox's table, windows 7 drivers are definitely not available for the 7132. The latest drivers are for Vista, but that's not necessarily a bad thing, because windows 7 can run vista programs in its compatibility mode, or many times it works alright after downloading and installing the vista drivers.
Hope this helps!
3helpful
3answers
Need driver for xerox docuprint p8e printer for windows 7 32 bit to install
Try this:
http://download.support.xerox.com/pub/drivers/GLOBALPRINTDRIVER/drivers/win7x64/pt_BR/X-GPD_5.246.7.0_PCL_x64.exe
1helpful
I need the driver for my win7 of docuprint c525a
You may be able to download a Windows 7 printer driver from the Xerox WEB site.
Please click on this link and select your model printer to download :-
5helpful
3answers
I can not install this printer in windows7 operating system
Hello.
Unfortunately, Xerox doesn't yet offer Windows 7 support for your device. However, they announced a release of the Windows 7 driver until June 2010.
Still, you can try installing the Windows Server 2008 driver:
http://download.support.xerox.com/pub/drivers/6110MFP/drivers/win7/cs/Phaser_6110MFP_W7.zip
Source:
http://download.support.xerox.com/pub/drivers/Compatibility_Matrix/other/win7/en/Windows7_Matrix.pdf
Now ... are you sure your device is not 6110MFP? Because Xerox Phaser 6110MFP does have Windows 7 support and you can download the driver here:
25helpful
3answers
Need a windows 7 driver for a workcentre 7132
Sure, download this tool Driver Update Software for XP Vista 7 8 and make your update in no time. regards. SImon
4helpful
Where can I download the driver for Fuji Xerox DocuPrint C1110B color laser printer?
You can download a latest driver for Fuji Xerox Docuprint c1110b Color Laser Printer in this URL
http://www.fujixeroxprinters.com.au/en/support/Downloads.aspx?product=8645&category=5726&os=8388608
Driver Version: 2.6.15
Driver Languages : English, Chinese - Simplified, Chinese - Traditional and Korean.
Operating System
Microsoft Windows XP Microsoft Windows 2000 Microsoft Windows 2003 Microsoft Windows 2003 64bit Microsoft Windows Vista 32bit Microsoft Windows Vista 64bit Microsoft Windows XP 64bit Microsoft Windows 2008 64bit Microsoft Windows 7 Microsoft Windows Server 2008 Microsoft Windows 7 64bit
Printer Language: PCL
WHQL: Yes
2helpful
2answers
Printer
You should be able to download from this site:
http://download.cnet.com/Xerox-DocuPrint-M750/3000-2116_4-149072.html
Copy and paste in your browser
M750 driver for Vista
According to the Xerox web site there are no plans to develop a Vista driver for this printer. I was unable to find any other source for these drivers.
2answers
Windows Vista Note: There are no plans to develop Vista drivers for the Xerox Small Office/Home Office products.
thats the answer from xerox.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
