Question about Rotel Audio Players & Recorders
Fuse for rotel amp for RB-870BX
Fues is blown, tried a 7amp fuse but it keeps blowing fues
    New Friend:
    Problem Solver:
  • 9 Answers
IF THE FUSE YOU ARE PLACING IS THE SAME TYPE AS THE ORIGINAL YOUR AMP HAS A PROBLEM WHAT YOU MUST DO IS TO SLIGHTY INCREASE FUSE BY 100 MAMPS PER TIME IF IT IS IN THE TRANSFORMER CIRCUIT YOU CAN INCRESE IT BY 2 AMP MAX IF IT IS IN THE MOSFETS CIRCUIT YOU CAN INCRESE IT BY A MAXIMUM OF 500MAMP LET ME KNOW THE RESULTS
Posted on Jun 14, 2014
SOURCE:
SOURCE: Rotel rx 1050...Not working
If you are not using the 12v trigger between pre-amp and power amp make sure that the trigger switch on the rear of the RB-1070 is set to off
Posted on Feb 12, 2008
  • 4234 Answers
SOURCE: KEEPS BLOWING SOUND FUSE
When you refer to the "sound fuses" are you referring to the speaker protection fuses or the power supply fuses?
Dan
Posted on Jan 14, 2009
  • 4234 Answers
SOURCE: gem sound dj amp blows fuses on the right side
There is a problem with the output section. The most common cause is shorted output transistors. This unit should go in for service. Without seeing the unit and testing it, I can't indicate all of the defective parts. You should expect a parts cost between $25-$45.
Dan
Posted on Feb 18, 2009
  • 561 Answers
SOURCE: I have no sound coming from my amp a rotel rb 981
it is never advised to change wires while the amp is switched on. you may have blown your diodes on your post amp then you have a problem.
have you tried other speakers tested your speaker on another system to rule them out as OK?
if you open the case be careful not to touch any large capacitor as they may still be chared and can give you a nasty belt.
any fuses should be easy to find and to see if they are blown. ensure you get the same rate fuse when you replace. if you see any charing of diodes then i think repair may be costly. good luck.
Posted on Nov 12, 2009
  • 211 Answers
SOURCE: the two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
Posted on Jan 17, 2010
I am install 20 amp fuse and it still blows
Sounds like you have a direct short somewhere. Closely examine your wiring harness for bare wires and pay attention to anywhere wiring is running on or through hot or sharp areas. Does the fuse blow as soon as you plug it in, or only when you turn the key?
Jun 21, 2018 | Troy Garden
Computer \ ing fues keep. Blowing for 1994 s10
Need a wiring diagram & study all the components
in the circuit, that has the blown fuse
Then start testing those items, that are most likely
suspects
Also check for wiring harness rubbing somewhere
Sep 24, 2014 | Chevrolet S 10 Cars & Trucks
Ive lost all power to my trunk pop radio seat adjustment and memory and power locks please help
Check your fuse panel for a blown fues if there is one blown and it keeps blowing after replacing check for a broken or pinched wire especially in the door jam
Jul 17, 2012 | 1998 Buick Park Avenue
I'm fues to my fan keeps going out on my 2006 P.T
More than likely you have an internal fault either in the fan itself or the thermostat that activates it.
For a fuse to blow it has to have a lot higher than normal current draw through it, which is normally refered to as a short. If the fuse blows almost immediately then I would suggest you unplug the fan, and see if the fuse blows with just the thermostat in the circuit. If it blows - replace the thermostat control. If it doesn't blow, plug in the fan and watch it. If it trys to start and then blows the fuse, replace the fan motor.
Jun 30, 2011 | 2006 Chrysler PT Cruiser
1998 Mustang: how to fix horn on 1998 ford mustang...
Verify that your getting 12 volts at the connector of your old horn. if present replaced the horn. if no voltage, verify fuse protector.
May 17, 2010 | 1998 Ford Mustang
Every time i turn the ignition on,, a 20amp fues blow out ..the car is not starting..it will turn over but not start... the fues is in the power distibutor box only
what is that fuse for? If it keeps blowing then it is an indication of a short cicuit in the part/cable/wire for the unit the fuse protects.
Oct 03, 2009 | 1997 Ford Thunderbird LX
Why do my fues keep blowing on my daewoo
First I suggest confirm what fuse blowing there and waht circuit and edevices are controled, check some wire broken or bad ground in the line and switch (if have one there).
Keep us updated.
Mar 27, 2009 | 2001 Daewoo Leganza
Fues blown in xpower inverter 1750 plus
These fuse are often intend to protect voltage inversion. (reverse voltage)
So, if the eight fuse are blown, then maybe the voltage red and black wire were not connected to the correct polarity.
then again, even if these fuse are intend to be use as reverse protection, it may occure that transformer short out, transistor short out and many other short circuit inside the inverter as occure.
So replacing all eight fuse might not restore the unit function, they may even blow again.
Also, reversing polarity that cause the fuse to blow might have damage the transistor stage.
I am still, investigating few other problem with those unit.
I don't have all answer yet.
regards,
Hitheck
Dec 21, 2008 | Xantrex Technology Xantrex Xpower 1750...
Blowing fues
Are you sure you can put a 2 ohm load on this amp? Thats almost a complete short.
Jun 13, 2007 | Rockford Fosgate Punch 301S Car Audio...
386 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
