SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition
Check/Repair
F0 or F1
Failed transistor in control
If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked
If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F3
Open oven temperature sensor circuit
Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
F4
Shorted oven temperature sensor circuit
Same as above; check for melted connector or both leads shorted to ground
F8
Component failure within Electronic Range Control (ERC) effecting temp processing circuits
Replace Electronic Range Control (ERC)
F9
Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch
Check wiring and test operation of switch
SOURCE: MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
SOURCE: how does self cleaning work
Self cleaning would be better named... Running the oven real hot to burn off residue.. so in essence, the oven is locked out and then heat is raised to a high level to bake out grease and food byproducts so they either burn off or turn to ash for easier cleaning.. Does that make sense to you? Most self cleaning ovens lock out the user until the oven has cooled down to a safe user-friendly level..
SOURCE: Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
