SOURCE: ARCHOS pc recognition problem
Hi Again
I have solved my problem. After searching elsewhere I found another site with a few users with the same issue.
A new USB lead is the solution.
SOURCE: PC no longer recognizes my Archos 605
I had the same problem with my Archos 605 and here's how I fixed it....
Right click on My Computer, then click on Properties. Under the Hardware tab click on Device Manager. My Archos was shown under Portable Devices but with an exclamation point next to it. I right clicked on Archos 605 wifi and then clicked on Update Driver. This updated the MTP driver and now everything is working fine.
SOURCE: My archos 605 [160gb ] not recognized on my PC
I recommend trying your archos on a different computer just to see if it is a pc or archos problem. Your pc should come right up and ask if you want to charge or use the usb port or both. Try another computer.
SOURCE: how do u charge archos clipper mp3 player using
just attached the usb cable to mp3 player and put in2 computer to charge for couple of hrs
SOURCE: the archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
