The router is connected to the modem and my laptop's internet connection is working through the router. Now i want the ipad to connect but i forgot the password. how do i recover it without resetting the whole thing. i can't log in on the dlink website either. username: admin password: doesn't work. help?
SOURCE: secure dlink di 524 with wireless connection.
One of your neighbors may have changed it for you, but you have the hardware, just reset it, and get a LONG cable to it, as you only get problems trying to set the Router with the wireless connection.
After resetting to factory default,
Change admin password
Set wireless security:
Wikreless/Wireless MAC filter.
- here you allow witch MAC address is allowed to access your network.
you find your own MAC address by typing ipconfig /all in a cmd.
/Teis
Dont forget to vote if this is helpful
SOURCE: Not able to Login to us robotics 9108 adsl modem
Try admin for the username with a blank password.
Chris
SOURCE: DI-624 can't login as admin
Try connecting directly to the router with a cable as if there is a problem with the wireless connection then you won't be able to connect. If you are already connected directly then reset the unit to it's factory defaults: Locate the Reset button on the back of the DI-624 (through a small hole next to the power cable). Use a paper clip to press the Reset button Hold for about 10 seconds and then release. After the DI-624 reboots (this may take a few minutes) it will be reset to the factory Default settings. Now try to login again directly via a cable.
SOURCE: LOGIN FAIL
at the back of the router is a tiny hole, so while router is on and working push the paperclip or something inside and hold for at least 10secs. This step will reset the router to factory settings and you'll be able to login again
