Please suggest a sollution for removing write protection from my pen drive
If u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Did not find StorageDevicePolicies...........................????
I did not find storagedevice policies
this is not helpful
How to solve this problem?
My problem is my pendrive is write protected. how its possible?
Hi aslamkhan,
In your pen drive, check if you have a "hold" switch or button. That may cause this write protection. So press that switch which may solve the problem. Can I know the model number of your pen drive?
Hello & Hai
Its vishu
Pen drive is write protected then download this software install and go for repair and the pendrive is reusable (read/write/delete/format)....
[email protected] is my id
My pen drive is 32gb kingstone
it is gone automatically write protected....
in my pen drive not copy any file plz help me
thank you
sir
How to rmoving write protection on pen drive
HIII I Have a kingston 32 GB data travel.when i format this using NTFS or FAT32 unable to comlete format.when i plugin drive and just try formating using exfat its formated.and now i try to copy data in it after 1-2 mb copied it says write protected.please help me. my email is [email protected]
thanks in advance.
I WANT A PAN DRIVE BOOTABLE SOFTWARE
BECAUSE I WANT TO INSTALL WINDOW WITH PAN DRIVE
AND HOW TO REMOVE RIGHT PROTECT PAN DRIVE SOFTWARE
PLZ SEND ME ON MY MAIL ID [email protected], KAMALGUREJA @GMAIL.COM
I have used a USB pen drive, But when i tried to copy something in ti it says "write-protection"
Pls solve this.
Thanks & Regards
gaurav banyal
My pen drive write protect pls solve problem
i HAVE A PEN DRIVE 32GB IT IS GONE AUTOMATICALLY WRITE PROTECTED..
i AM UNABLE TO EDIT THE FILES ON PEN DRIVE PLS
WHAT ARE THE STEPS TO UNLOCK THE WRITE POTETION OF PEN DRIVE..and
how it happens...when it hapeens PLS EXPLAIN TO ME
i have pen driive of 2gb plz give me solution to remove write protection of this disk.
how it happens...when it hapeens PLS tell me solution
i have same problem in my pen drive (8 GB transrand) i try to solve as per your instraction but i con' t see in my pc system storage polices
how can i remove write proteced
