It wont move it works but the weals dont move
Check that the chain is still on both the drivewheel(the part on the motor) and the freewheel (the part on the wheel). If that is connected well, check if the chain moves when you rev it. If the chain moves but the wheel still doesn't move, the freewheel, or gear connected to the wheel, is probably broken and you need to get a new rear wheel. If it doesn't move, the motor is most likely shot, and you're going to need to order a new motor, unless you are confident in taking apart the motor and replacing whatever needs replacing within it.
