For
OBD code problems check the list of help links below. Click the link
below to go through its procedure. -------------- ------------ http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html --------- -------------- ------------ ------------- -------- ------------ -------------- ------------ http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html ---------------- http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html -------------- http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html ------------ ------------- http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html -------------- http://howtobyme.blogspot.com/2011/11/code-p0452.html ------------- http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html ------------- http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html ------------------ http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html ------------- http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html ----------------- http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html ----------- http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html ---------------- http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html -------------- Part 1. http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html -------------- Part 2.------ http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html -------------- http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html ------------------ http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html ------------- http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html -------------- http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html ------------ http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html ------------- http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html -------------- http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html ------------- http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html ----------- http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html ----------------- http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html ------------- http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html ------------- http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html ------------ http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html -------------- http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html ----------- http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html ------------- http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html --------- http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html ------- http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html --------- http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html ----------- This
will help. Thanks.
OBD Code is cleared but check engine light will not RESET?
Diagnostic Code P2195?
http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330?
http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330?
http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300?
http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768?
http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions
System codes details?
http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html
Engine Misfire codes?
Misfire on cylinder 4?
ABS trouble codes for all models?
Diagnostic code P0010?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
Code P0452?
OBD code P0172 on Buick?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
OBDII scan is receiving NO
BUS CODE?
How to Clear OBD error
Codes?
Diagnosis and Testing Car
Components?
Diagnostic Trouble Codes
list?
list?
Diagnostic Code 43 and 71?
Code P0132?
P0031 code?
How to get diagnostic Code
without OBD Scanner on Pre 1995 cars?
OBD-II Trouble Code P0300?
Getting diagnostic code
P0016?
How to Read Codes from
Check Engine Light?
Diagnostic Code P0540
continues to return and the MIL light is on?
DTC Trouble Code P0401?
Car misfires and error code P0306 and P0303 is
shown?
Diagnostic code P0463?
Check engine light with
codes P2195 and P2197?
Diagnostic error code
P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
P0174, P0037 and P2197?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0301, P0430 and
P0174?
OBD code P0500?
SOURCE: Check engine light. got 2 codes P0172 and p0175.
Unclip the 02 harness, then take out the 02 sensor. 5 minute job.
SOURCE: I got codes, p0172 and p0174 (mustang gt 4.6L)
When these codes are tried together it usually means O2 sensors are going bad. I suggest you get a real scanner on it before you spend $$$$$
SOURCE: p0172,p0175,p0300 trouble codes on 2006 chevy
Engine is running rich--may be the cause of the misfire code as well. Couple things to try. First, clean the MAF sensor by spraying with electrical parts cleaner. Also, try adding some injector cleaner to the tank.
CHECK THE AIR INTAKE TUBE FOR TEARS OR LEAKS. A LARGE VACUUM LEAK WILL CAUSE THIS.
