I do not want to use NSpro 3,7 because it is too expensive(you can buy a new phone with such amount of money). Is there any freeware to reprogram/flash IMEI back into Samsung SGH-G600 memory??
I put the unlock code in yesterday which seemed to of worked, but when i put an orange or o2 simcard in, it didn't want to work. Plus my IMEI set to all zeros and i'm not happy about it, can anyone help me solve this please.
Thanks
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: Samsung SGH-G600 IMEI reset to all zeros after using so-called unlock code
I've got stuck with the same problem, so far can't use o2, but other sims work
SOURCE: Samsung SGH-G600 IMEI reset to zeros after using so-called unlock code
The following worked fine on my Samsung SGH-G600 which was on 02 and now can be used with any sim:
*7465625*638*00000000*00000000#
NEXT ENTER
#7465625*638*00000000#
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
JohnJ
i have the same problem
i had the same problem, take it into ur nearest service station and they will rebuild the imei for £20
