Always when I Switch off the Mobile and open Again I see Message for System erroe when I Press ok The message Disappear
SOURCE: Voicemail message
This problem has arisen before from a software conflict between Orange and Nokia. Orange could not cure it but a firmware update is scheduled to deal with it. I couldn't wait so I placed my SIM in a spare phone, called my mobile number and left a message from a landline, listened to the message on the alternate phone, deleted it and bingo the voicemail icon disappeared. I put the SIm back in the N73 and touch wood its not returned. Hope this works for you because if you are on Orange...you are on your own.
SOURCE: Message are not deleting.
You might be looking at delivery reports they delete via the OPTIONS all at once or none at all.
If it's the contents of the msgs, move them to DRAFT, EDIT them to nothing or just blank then save them.
Then you should be able to delete them.
SOURCE: got a message on my Nokia N73 'unable yo perform
sir just hard reset your phone hard reseting code is *#7780# type this on your phone`s keypad it will not delete your any data
SOURCE: how to get PUK code
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code is unique for each mobile phone model.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
1.
Switch off your Nokia phone.
2. Hold down the
following three keys, Green (call answer button) *
Key, and Number '3? key.
3. While holding these buttons, press the power button
and switch on the phone.
4. Wait for message
'Formatting' to appear on the screen and release all keys once you see
that message.
Method 2: Hard Format of Nokia Mobile Phone
1. Switch off your Nokia phone
2.
Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button
5. Wait for message
that message.
Method 3: Soft Reset of Nokia Mobile Phone
2.
Now Press following key sequence *#7780#
button and switch on the phone.
5. Wait for
message 'Formatting' to appear on the screen and release all keys once
you see that message.
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
