I make some video with my mobile phone and i kept the files in the card. but everytime i open it and i cant find the videos.it shows free space 384 MB and used 1.45GB.but i can only view some of the used space.i set to show all hidden fil & folders.but still not getting all the contents.how can i show all the files, plz.
Memory card recovery is a crucial job, and its even tougher if the card is damaged, I'll say go to professional for help or else you might loose all data on it.
1. Do NOT attempt to write anything new on
this memory card.
2. Download a memory card data recovery freeware
to help you. There are many data recovery tools out there. But, no all of them
could be efficient and useful enough. You should pay much attention to opt for
a proper one.
Try to read this: http://www.geeksdo.com/data-recovery/memory-card-photo-recovery.html
3. Run the selected recovery tool to
retrieve your inner videos files.
Note: Actually, in your case, if you have
backed up everything important on another card or drive before, you would not
have so many troubles. Therefore, you should learn a lesson to do regular data
backup.
As the digital technology is moving fast and data loss is associated with the same speed too. So to overcome from data loss situation you can make use of Remo Recover Windows Free Edition to recover your lost or deleted data from memory card along with any type of storage devices..
If you do a full format, all the data on the disk will be overwritten with the formatting data - and you will lose the data you want to retrieve.
If not, you can download the data software from http://www.any-data-recovery.com/product/datarecoveryprofessional.htm to recover data from Memory card
How to recover data from memory Card:
Memory Stick Recovery - Recover lost memory stick data
Have you deleted your files (music, videos, photos or documents) from your Memory Stick wrong? And you are finding Memory Stick Recovery
software to recover the deleted files? If yes, keep reading. This tips
shows you how to recover deleted/formatted files from your Memory USB
Stick.
How to recover data from memory stick:
1. Download Finalseeker Card Data Recovery software and install it in your windows..
Free Download Finalseeker Card Data Recovery software
2. tart Finalseeker Card Data Recovery software and insert memory stick to computer.
3. Select one or more file types you want to
recover from memory stick. If the file type you want to recover isn't
photo, music, or video, you can select all option. The all option will
retrieve all file from you memory stick.
4. Select a USB Drive to scan and retrieve the lost data. Tips: You can find the USB drive at Removable Media1 category.
5. Preview to choose the file you want. If the
file cannot be preview, you also can recognize it by the file size and
file name suffix.
6. Click the Recover button to recover the lost
file to another partition or drive. Tips if the file has been
overwritten by new data, the recovered file may not be able to be open
correctly. If this happen to you, the best way is to try to use other memory card data recovery software.
SOURCE: I CAN`T PUT MUSIC IN IT
Make sure that the microSD card is formatted. You may reformat the memory card using your phone and then try saving some music.
If that will not do any help, try using another microSD card to see if the card is defective.
Have a great day!
SOURCE: Downloaded Frostwire to USB Flash, can't delete Incomplete Folder
if you are the admin of the computer..you should be able cut it destroy it...but we are talkin about a 2 gb flash drive..if nothing is on it format the drive (if some files are on it click & drag files to pc...this is less then 10 min job and format the drive, then reinstall the data back onto the flash)...for future downloads and to avoid downloading to flash then pc...always check http://download.cnet.com/mac/?tag=hdr;snav
here you can review software, download software....this site will tell if what you about to download is worth the try or not.....frostwire and limewire are good and was no need to download on flash... my goal was to help 300 people with selected problems...you are the 3 0 0 th (and final)..i hope this is helpful to you ...keep the cnet link...thanks for being on FIXYA......(my closing to all those i've help) final line that i type here is .......Feel free to rate the help
SOURCE: microSD card isn't recognied in my Env3
card may have virus and you need to sacn it computer antivirus sytemprevent to access it or it needs to format
SOURCE: Can't get iTunes files to my Blackberry via a card reader
If you bought the music from itunes than you might not be able to add songs to devices like phones because apple formats their songs to not be played from anything but ipods.
SOURCE: Downloaded Frostwire to a memory stick, can't delete folder.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
