Question about Samsung MC1360WA Convection/Microwave Oven
Samsung M1630 stepdown transformer details
Hi, I need toknow the transformer details for this oven M1630N. Looks like its primary winding is blown off and no one wants to rewind the same. Hence looking for substitute with similar ratings. Would appreciate if someone can post the specs for this transformer. Thanks Regards Prasad
  • Samsung Master
  • 9,156 Answers
That model doesn't show up at my normal Samsung US parts supplier. Can you post all the numbers found printed on the transformer? One of them should be the Samsung part number. Normally you can look at the voltage rating of the large filter capacitor on the control board and assume that the AC secondary voltage will be about 2V less (in ACrms) than that DC voltage. Now what I'm saying may seem a bit twisted - and it is - but what I mean is this: If the cap is rated at 15VDC, then I'm saying that a secondary voltage of about 13VAC rms should be a good safe level for testing. To confirm this, multiply 13VAC by .635 (assuming it uses a full-wave rectifier) and you get about 8.26VDC. Then allow for about 50% derating by mulitplying the 8.26VDC by 2. This gives you 16.5VDC, which with my generous derating, is pretty close to the caps 15VDC. Then you can remove the transformer and use an isolated Variac(tm) to apply that calculated AC voltage to the secondary connections at the circuit board to see if it powers up. You can measure the DC voltage across the cap as you adjust the Variac(tm), making sure you don't get too close to or exceed the DC rating of the cap. Once you get it working with a main DC voltage of about 50-75% of what's printed on the main electrolytic capacitor, you can start shopping for a sub transformer. It's much easier if it's not a VFD display which would require a separate filament winding, but there's nothing wrong with using a small second transformer for that. You can even mount them both on the chassis and run long leads to the board. As long as the leads are of sufficient gauge, routed and secured well, and protected from nicks, there's nothing worng with that technique. You should make them long enough that if the front panel is later removed for service, the next technician will be able to see the wires before he pulls them out or otherwise damages them. I would also add a varistor on the primary if there's not already one! *grin*
Posted on Nov 01, 2006
SOURCE:
I NEED TO KNOW TO CONNECT THE WIRES FROM THE TRANSFORMER CAPACITOR AND MAGNATRON
One side of the high voltage winding is usually connected to the frame of the transformer. Verify to make sure this is the case. The other end of the winding goes to the capacitor terminal that's not connected to the rectifier. There should be another high voltage wire that goes from the rectifier side of the capacitor to the magnetron. And, there should be two wires that go from the filiament winding on the transformer to the magnetron. The primary winding should be connected to whatever supplies 117 vac to it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 07, 2016 | Microwave Ovens
Good day,subject: LG microwave oven MS3448XRS not warming contents.Checked High voltage transformer 240 volt AC input-ok.Measure primary winding(0.2-0.4 ohm) measuring 1.1 ohm,secondary winding(70-100
Probably cheaper to buy a new microwave as they maintenance charge can be costly once put on a bench.
I am not able to help with this item.
Oct 01, 2014 | Microwave Ovens
Why is there a humming noise coming from the right, front bottom corner of my microwave when not in use?
That is because the power transforme is located in that area and being a transformer uses iron laminations to transform the energy from the primary winding to the secondary winding/s using magnetism caused by the alternating currents. This in turn produces eddy currents that excite the iron and cause vibration to be set up, (the principle is similar in a loudspeaker). That is where the noise is coming from.
Tightening up the laminations may help but it is normal for a small amount of humming/buzzing noise dependent on the manufacturing process of the transformer.
I hope that explains it for you.
Oct 28, 2010 | Hotpoint RVM1435 Microwave Oven
Microwave won't work
Check the AC fuse in side the oven. If the fuse is ok chek the low voltage transformer . If the primary winding is open replace the transformer.
May 25, 2009 | Frigidaire FMT148GP Microwave Oven
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
May 23, 2009 | Microwave Ovens
No power problem
Check the AC fuse and the low voltage transforer primary winding open. If it open replace the transformer or rewind it.
May 22, 2009 | Sharp R-316FS Microwave Oven
LG MS-2143RSL MICROWAVE OVENT NO HEAT
hi i am suggesting that it is probably the magy as the res to grndis a bit low and therefore loading the sec supply down , just a thought
cheers grant
Oct 23, 2008 | LG LRM1250 Microwave Oven
Any Whirlpool Microwave Techs out there...Please help a fellow tech
hi mike,
I’m sorry to tell you this but; I wouldn't recommend using a different transformer, even if it's the same size, it could cause serious damage. The HV transformer should only be replaced with the exact replacement part.
Mar 21, 2008 | Microwave Ovens
Samsung MC1360WA Convection/Microwave Oven Logo
304 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Steve Allison
Steve Allison
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
