Hyjacker, Ransford decker ask 6 years later.
ahhh , old BEEPs codes so old that HP even forgets them
over 10 years old./ yours is now 13 years old
first off is the Motherboard RTC coin cell dead, as all are this old?
replace it first. a wise choice. that.
on some HP code 8 is coin cell dead. did you count flashes wrong? the count matters. big time....
on AMI BIOS code 8 means
Display memory error (system video adapter)
later AMI BIOS code 8 means.
ROM Checksum Error
ROM checksum value does not match the value encoded in BIOS.
this means COIN cell bad again.
i see no code 9,s in my huge private lists of bios codes for 20 years.
ok , reading all manuals, on this one PC i find this.
"System not fetching code"
now there is classic geek code, wow.
my guess it means CMOS ram is corrputed.
again the coin cell is bad. table.(fixha wrecked it, sux, no?)
SOURCE: hp compaq dc 7600
When you boot your computer, you need to hit the key to get you into the bios setup. F10, F2 or Del keys are the usual ones.
Once into the bios, change the boot order to make the CD drive first, and then you will boot right to the CD.
Note, you will also have to hit a key when it starts to boot, it will say, hit a key to boot from CD.
If you miss the key to get into the bios, you have to start over again. Sometimes you have to hit the enter bios key over and over to get in there.
SOURCE: Pc hp dc 5000 sff does not power on, a red light
sounds like you have your answer, your computer is hosed. unless you want to keep swapping parts to try to see if it's memory or cpu, I'd just get a new motherboard/cpu/ram combo (they've come a long way since you got that computer, I'll bet)
SOURCE: won't boot. Series of Beeps plus red light
If nothing was displayed on the monitor during the beeps then change the RAM stick(s)
Thanks
SOURCE: Audio Panel HP DC 7700 Minitower case with Hp 7600 motherboard
go to the manufacturer site and download the manual ...not just the schematic...in the manual you have the picture with the pin numbering ..and the functions .(places on the plug ..) and the wires are labeled
SOURCE: i cannot install pci device
pci device driver in hp dc 7600.
go to Google.ca search for uPCI-200L.
Download the driver for that device..and solve the problem.
Your PC has 2 PCI serial port (comA and comB).
Good luck.
