Installed Print Shop 23.1 Deluxe on a new machine - Windows 7 64 Bit. It takes literally 5 minutes to load and freezes when previewing. It worked on my old Windows 7 32 Bit machine with no issues. I installed, uninstalled and reinstalled several times. No luck. Tried compatibility mode - no luck there either...
SOURCE: My system is windows vista 64 bit. Print shop
you have to go to the help section or help tab at the top of your printshop window, on your printshop program...and then click technical support , and it will give you options...click on the option of troubleshooting and it will take you to the broderbund direct online troubleshooting page, and click on the appropriate option for windows vista 64bit, and it will walk you through step by step; which involves going into your printer port settings under control panel section of your computer, and just follow the online directions...I just did it and my newsletter on printshop 23 deluxe is now saving without problems!
SOURCE: I am currently using both
Printshop 23 won't save to broderbund pdf creator or pdf complete creator. Either a Printer is not activated error 30 or cannot communicate with printer.
I have used Printshop for years......have had no problems with printshop until this new Printshop 23 version for windows 7.
Have uninstalled and reinstalled everything at least 3 times. When I go to the "help" button there is no technical support button. Any ideas out there?
