La Crosse Atomic Digital Wall Clock with Moon and Temperature Logo
ra hiramoto Posted on Mar 02, 2012
How do you turn off the alarm ona La cross atomic clock
The alarm on my atomic clock keeps waking up the family,. How do I turn it off?
3 Related Answers
Anonymous
  • Posted on Feb 17, 2008
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Anonymous
  • 2761 Answers
  • Posted on Mar 19, 2010
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
gopakumarg43
  • 76851 Answers
  • Posted on Jul 31, 2011
SOURCE: my La Crosse Radio controled
Hello
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
Ok.
How do I set my La Cross atomic alarm clock?
They make lots of models. So lots of videos and manuals here. Some do it from a time server once you set the time zone.
https://www.google.com/search?q=set+my+La+Cross+atomic+alarm+clock
Mar 19, 2021 • Home
How to set an atomic alarm clock
Hello
I've the proceedings to setup the atomic clock, but this window does not allow me to send it by copying and paste the document, as it is out of this window's capacity. If you send your email address to me by Fixya comment box, I'll send a copy of it to you by return mail. OK.
1helpful
I need a manual to reset the projection.
Hello
I've the manual you need; for La Crosse WT5110 radio controlled projection alrarm clock. But I can'e send it to by this site, as it does not allow me to send such a large file. If you send me your email address by Fixya, I'll send it to you by return mail. OK.
The second hand on our LaCrosse atomic clock has stopped moving but the clock continues to keep perfect time. How do we get the second hand turning again?
The manual for one of their clocks says the clock will change the second hand to two-second intervals to conserve energy when the battery voltage gets low. Perhaps your battery is VERY low.
How do i deactivate the alarm on atomic projection alarm?
This site lists several including some desk models on two pages and each has unique downloadable instructions.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
This one may fit the bill...
http://www.klockit.com/PDFs/lacrossemanuals/WT-5360U.pdf
Bill B
27helpful
Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
