Computers & Internet Logo
Posted on Oct 30, 2008
Radeon X1300 - Windows has stopped this device because it has reported problems
I have an HP XW6200, with NVIDIA Qudro PCI-E working fine with dual monitors on Vista 32 bit OS. I added a Radeon PCI X1300 so I can use a third monitor. However, after installing the drivers I continue to get "Imcompatible display adapter on the system has been disabled because its driver is not compatible with the driver for the VGA adapter.
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Dec 25, 2008
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
5167
Points
60
As far as I am aware, you can not run an ATI card in the same system as an Nvidia card due to driver conflicts.
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
40helpful
2answers
1helpful
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
1helpful
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Installing ati radeon x1300 graphics card
try installing the drivers from this site: http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_vista32.aspx?type=2.4.1&product=2.4.1.3.7&lang=English
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
A8N-SLI Premium & NVIDIA GeForce 7800GT
Sounds like your getting conflicts with running two different card drivers. I've never heard of running a PCI and a PCIe card at the same time.
EA Game ''Spore'' - Videocard & Driver Issue
Well, I can solve it but it is somewhat bad news. Basically your video card is not powerful enough. Here are the ATI specs from the EA website;
  • ATI Radeon™ series
  • 9500, 9600, 9800
  • X300, X600, X700, X800, X850
  • X1300, X1600, X1800, X1900, X1950
  • 2400, 2600, 2900
  • 3450, 3650, 3850, 3870,
  • 4850
    and here are NVIDIA
  • NVIDIA GeForce series
  • FX 5900, FX 5950
  • 6200, 6500, 6600, 6800,
  • 7200, 7300, 7600, 7800, 7900, 7950
  • 8400, 8500, 8600, 8800
  • 9600, 9800, GTX 260, GTX 280
    I would recommend buying a new video card. You can pick up a NVIDIA 8400 thru 8600 for about $30 or $40 from Frys.com or newegg.com sometimes cheaper with rebate.
    They are fairly easy to install.
    Good Luck.
    Program won't run, error message says it can't find 3d software.
    If the error message says "Cannot find any compatible Direct 3D devices" it means that you do not have a supported video on your system, and that you need to upgrade your video card.
    The Recommended and Minimum System Requirements for the are game mentioned below your system has to meet at least the Minimum System Requirements for the game to launch on your system.
    Recommended System Requirements:
    - 3 GHz Intel Pentium 4 or equivalent processor
    - 1GB System Ram
    - ATI Radeon X800 series, NVIDIA GeForce 6800 series or higher video card
    1.2. Minimum System Requirements
    Minimum System Requirements:
    - Windows XP
    - 512MB System RAM
    - 2 GHz Intel Pentium 4 or equivalent processor
    - 128MB Direct3D compatible video card with DirectX 9.0c compatible driver
    - CD-ROM or DVD-ROM drive
    - 4.6GB free hard disk space
    - DirectX 9.0c (included)
    - DirectX 8.1 compatible sound card
    - Microsoft .NET 2.0 Framework for toolset (included)
    - Broadband connection for multiplayer online play
    - Keyboard, Mouse
    1.3. Supported Video Cards
    - ATI Radeon X1900 series
    - ATI Radeon X1800 series
    - ATI Radeon X1600 series
    - ATI Radeon X1300 series
    - ATI Radeon X850 series
    - ATI Radeon X700 series
    - ATI Radeon X600 series
    - ATI Radeon X300 series
    - ATI Radeon 9800 series
    - ATI Radeon 9600 series
    - ATI Radeon 9500 series
    - NVIDIA GeForce 7900 series
    - NVIDIA GeForce 7800 series
    - NVIDIA GeForce 7600 series
    - NVIDIA GeForce 7300 series
    - NVIDIA GeForce 6800 series
    - NVIDIA GeForce 6600 series
    - NVIDIA GeForce 6500 series
    - NVIDIA GeForce 6200 series
    - NVIDIA GeForce 6100 series
    - NVIDIA GeForce FX 5900 series
    - NVIDIA GeForce FX 5700 series
    - NVIDIA GeForce FX 5600 series
    - NVIDIA GeForce FX 5500 series
    HIS Radeon X1300 Misdetected
    do the BIOS update !
    in the advanced BIOS features there should be a onboard GPU tab, put it on disabled or on initiate AGP/PCI first (depends on the BIOS), so to be sure that the onboard card is disabled !
    Connect the display to the HIS ...video card , and at least on bootup there should be info displayed on the screen . If not than : - try to reinsert the video card (bad connection ) (also check if its a card that needs external power source ( i doubt it))
    - check if the video card is compatible with the motherboard (should be in the user manual, or on the producers site ... )
    - check on another comp. if the card is good ....
    hope it helps u ... if not, give more details ....
    Top ATI Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Steve Sweetleaf
    Steve Sweetleaf
    Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
