SOURCE: Asko dryer 7005 will not start. When I touched
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Testimonial: "It was the fuse."
SOURCE: Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
SOURCE: My asko dryer 7005 works
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermostat. When the thermostat goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if thermostat reads continuity then please get back to me if you have any other questions.
Kevin
Testimonial: "Thank you for your response. Should we replace the thermostat as well as the heating element"
SOURCE: Asko 7005 dryer, start capcitor is cracked and has
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
