Maytag Atlantis MDG8400AW Gas Dryer Logo
Anonymous Posted on Mar 02, 2012
How do I light the pilot for this dryer? - Maytag Atlantis MDG8400AW Gas Dryer
Anonymous
Level 3:
Guru:
  • Master 462 Answers
  • Posted on Mar 03, 2012
Anonymous
Master
Level 3:
Guru:
Answers
462
Questions
Helped
252276
Points
1207
Gas dryers have had no pilot for several years. start the drier wiuth gas on and should fire off by3 to 5 minutes.
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Pilot
It probably has an electronic pilot light. It should light by itself. If you have a real old one, you have to open the cover at the bottom, and light the pilot.
How do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
2helpful
How do I light the pilot light
Gas dryers use an electronic igniter, there is no pilot light.
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
How to light the pilot?
If this is an electric dryer, it doesn't have a pilot either. If this is a gas dryer it will have an electric pilot. but then if it were a gas dryer, it would have a removable lower front panel for servicing the burner. So you must have an electric dryer. if the dryer runs but does not heat, the electric element is most likely at fault. If you really were looking for a pilot light on an electric dryer, I must recommend that you call a reputable appliance service regarding repairs so as to not jeopardize your safety.
Pilot
I'm assuming you have a dryer with a pilot light and not a spark lighter. If the pilot will not light, get a service tech. Gas is dangerous.
Pilot Lighting for Neptune Dryer
there is an electric igniter but no pilot light in the Maytag 5500 gas dryer. you can change it yourself.. let me know
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
