TOOK THE COMPRESSER AND GUN RIGHT OUT OF THE BOX HOOKED UP EVERYTHING PUT BRADS IN GUN PUSHED THE TRIGGER AND NOTHING IS THERE A SAFTY ON THE FRONT OF GUN THAT I HAVE TO USE THE ALLEN WRENCHES ON I HOOKED TWO OTHER GUNS AND THE SAME THING HAPPENED IS THERE A CORRECT WAY TO PUT THE BRADS IN THANKS
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
SOURCE: I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
SOURCE: i am trying to obtain 18 gauge brad nails for a
you should not have any problem with using any other brand of nail .18 gauge brad nail are pretty much the same in all brands.
Testimonial: "thank you for your advice it is much appreciated."
