SOURCE: goodman heat pump aruf estrips
cross check your info plate on the outdoor unit with the curcuit breaker installed in the main panel.
SOURCE: diagram for 10kw heat pack for carrier furnace
I hope this helps
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/wd-fa4c-01.pdf
SOURCE: Rheem Heat pump 5 ton heat strip 10KW what
I would say this is around 75 amps of draw at max for both the compressor and heat units. . Therefore--at least 90 amp breaker, and probably 100 amps for good measure, and at least #4 or #2 wire to the unit.
SOURCE: Goodman Air handler blowing fuse if switch outside unit not runni
Sounds like your compressor in your heat pump is siezed . You can try a "Hard Start" Capacitor...which basically gives your compressor a kickstart and works 95% of the time when compressors get older....It's hooked up in parallel with the existing Capacitor...if you're not familiar with Electrical etc I would call an expert and mention what I said . If this doesn't work you will likely need a new Compressor/Unit . You could also have a short to ground in the heat pump side....likely the compressor is the problem however the original Capacitor could also be the problem
SOURCE: Is there a filter in the goodman heat pump air
There should be. Take the bottom door off and look under the the blower assembly. There should me a 1" filter slot that goues under the entire unit. There may be another small door to take of to get the filter out.
