LG LRM1230W Microwave Oven Logo
Posted on Mar 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No heating after exploding sound lg
Exploding sound when turned on
Anonymous
Level 3:
  • LG Master 6,771 Answers
  • Posted on Mar 02, 2012
Anonymous
LG Master
Level 3:
Answers
6771
Questions
0
Helped
1779269
Points
21413
This indicates the magnetron has failed, "heart of the microwave oven" if everything else is working then the culprit is as stated above, often gives off a strong odor. In most cases it is cheaper to replace the oven rather than repair.
Whirlpool microwave made one sharp sound like a gunshot and now does not heat anything. Clock and function buttons work. Can it be fixed/
Sounds like the capacitor inside by the transformer exploded. It's an easy fix. just replace the capacitor.
Water exploded inside microwave
oh no, bad idear, forget it, if its blown up its a right off, never put bottles in a microwave,,,still there is some good news,,, you can now buy a microwave for about £50.00p so you wont need to sell the hubby
Lg microwave exploded hot water on my face
It's rare, but obviously can cause serious injury!
Your manual should address this, or for more on what causes this, read this article.
LOUD SNAP SOUND THEN MICROWAVE WONT HEAT
my microwave oven is a model lg lmv1630bb is making a loud snapping soud
Oven does not heat and makes loud, continuous "hum" when turned on and related to turning of oven table.
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
LG MS194A Not lighting up and heating up
It is probably a bad door switch (upper or lower) or one of the switch mounts is damaged or misaligned.
Some help here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
An exploded view is here.
Other exploded views and parts lists are here.
Since you are in PNG, you'll have to find parts locally or maybe via Stokes in Australia.
1helpful
LG MS-3444DPS microwave - spins but doesnt heat
Chances are you have shorted or blown high voltage rectifier diode.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/diode.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Galaxy microwave works does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uee
I had vinegar and oil explode in my microwave and now the macirwave will not shut off unless the door is open. What do I do?
Sounds like moisture may have gotten into the controls and / or the door switches.
You may have to remove the control panel to help it dry out.
You want to unplug it first.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
