Question about Samsung RS2630SH Side by Side Refrigerator
Samsung Refrigerator Samsung RS2545sh side by side refriderator: Freezer is at -4F but refriderator side is 59F and there is a constant hum. When hum stopped it went to 46F but 1 hours later hum came back and temp went back to 59F. Hum stops when door is opened. Thanks Frank
  • 4 more comments
  • fs9294 Nov 19, 2008
    Evaporator was replaced by repairman on refrigerator side but worked for only 4 days. I believe the solution from luigi44 is correct. Frank
  • Anonymous Nov 21, 2008
    same problem,
  • PollyB Nov 27, 2008
    Same problem with the refrig side warm. We removed the back lower panel to see the coils are frozen.  That explains why it took 18 hrs to reset after we unplugged it and why it only worked for another 3-4 days.  If replacing the panel and sensor is the fix, I'd like to know what part numbers to order.
  • Anonymous Dec 21, 2008
    I have the same problem. Have Samsung Rs2533SW.
    Refrigerator side is -4 but right side renains between 57 and at times goes to 54. Have changed fan motor in refrigerator (left side) Any help would be appreciated.
  • chan7272 May 11, 2010
    this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
  • krey May 11, 2010
    Which panel inside the fridge? I have the same issue with my Samsung fridge and am at my wits and wallet's end with this. If you can give me the exact part names that would be helpful.
    Thanks!
  • 22 Answers
This is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Posted on Nov 13, 2008
SOURCE:
Samsung refrigerator model rs2545sh/xaa. Freezer works good, but refer side does get cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
How can we install a electronic control panel on
very unlikeley to be the user control panel probably the freezer sensor or freezer fan not operating so no cold air circulating giving a false reading? is it colder at the bottom of the freezer than the top ? that is a dead give away for the fan
Jul 25, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Error codes for Samsung Fridge
you need to check the refrigerator defrost sensor connection thats behid the light bulb in the middle of the refrigerator section
May 24, 2009 | Samsung RS2534 Side by Side Refrigerator
New RS2545SH; Purchased new 4/9/2009
try off and on the power it might reset the board
May 05, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
640 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
