Cars & Trucks Logo
Posted on Oct 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Auto transmission. When in drive in 4th gear, not responding to acceleration, in fact slowed down when going up hill. Stopped then lost drive, revved engine in drive without moving. Moved into neutral and back into drive and started moving again. After a few minutes same happened again.
  • bradcoast2co Jan 12, 2009
    2005 RR auto transmission. Coming from a stop the vehicle goes in to a neutral mode then slams into gear again... Has anyone experienced this and where do you suggest to get it (reasonable priced) fixed??
    Thanks
  • loopymama Feb 19, 2009
    my auto has failed in drive, seems ok in reverse, in drive the auto semms to only engage, this has happened suddenly not of a period of time, would this problem be a major or relativly simple to repair
Anonymous
Level 3:
Genius:
  • Master 1,605 Answers
  • Posted on Oct 30, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1605
Questions
Helped
746923
Points
3939
Go to a transmission guy.
they should able to let you what the problem is.
check the transmission fluid first.
My Lexus RX300 will shift into overdrive once, and after slowing down it won't go past 3rd gear?
The Check Engine Light is on? Did you read the DTCs.
The second link has the answer, the first link says it is a known issue. It is times like this you need the Dealership or a good auto electrician.
Transmission won't shift to third until temp rise
ClubLexus https://www.clublexus.com > forums > 713188-transm...
Apr 1, 2017 - Transmission won't shift to third until temp rise ... The solution is to drive slow and keep rpms at 2.5k and 3k at max till the engine and transmission warm up.
Sometimes transmission wont shift from 3rd to 4th - ClubLexus
Aug 23, 2021
Won't shift from 3rd to 4th gear - Lexus Forum Discussion
Jan 25, 2011
RX300 not shifting into overdrive. - Lexus Forum Discussion
Jul 11, 2013
FIRST POST! RX300 no 4th gear a full year. Fixes? - ClubLexus
Jan 9, 2013
More results from www.clublexus.com
Owner of Lexus RX300 with 182000 miles. Recently the ...
JustAnswer https://www.justanswer.com > lexus > 3wsxt-lexus-rx3...
Aug 22, 2010 - Recently the transmission won't go into overdrive. Stays in 3rd gear like when you press the o/d button to do so. When car is cold (live in ...
1 answer · Top answer: Hello and thank you for using just answer! The check engine light is on correct?
https://www.google.com/search?q=Lexus+RX300+will+shift+into+overdrive+once%2C+and+after+slowing+down+it+won%27t+go+past+3rd+gear
Why is my transmission shifting down to third on hills while on cruise control when it never used to?
You will need to give specifics of your car, meanwhile I think it is normal, because when ascending, it is only normal for your vehicle to slow down, so a quick response by the accelerator is given to the need to maintain the speed which will in turn trigger the kick-down in ur tranny and send it to the 3rd gear, u will also notice that after it stabilises, the gear will shift into 4th and 5th smoothly.
1994 gmc sierra pickup 4.3L V6 automatic transmission experiencing difficulties with ODrive = 4th gear, and Drive = 3rd gear, engine revs up to the max properties with little to no forward motion. Rev
You have internal transmission damage I expect the clutches on third and fourth gear are wiped out. Its either that or a solenoid gone bad that holds those clutches pressure get it in a transmission shop soon to avoid whole transmission replacement costs.
1helpful
2answers
Wife was driving truck up a hill when it suddenly stalled out. she finally got the truck back down the hill. Now it will not idle properly, and stalls out if put into gear( R or 1st). Is this a carburator...
Depending on youre mechanical ability you can spend 20 bucks for a rebuild kit on your carburator.
There tends to be many different potential issues with youre description of the problem. My best advice for you at this time, would be get the carburator re-built and check youre fuel pump/fuel filter.
But you can always go to youre local shop and get a free estimate.
Clutch or Transmission?
Whining noise is worn gears or low on transmission fluid. It after reading your post, sorry to say but you were low on transmission fluid and your transmission needs to be replaced. You gear box has seized and every time you release the clutch even in neutral will kill your engine. The transmission shaft may have seized on the bearings in the transmission case, regardless you need a new or rebuilt transmission. Good luck friend and sorry for the bad news. Keep me posted.
1986 Toyota 4x4 Manual transmission
May be a bad rear end, Gear in rear may be broken check rear. Good luck and thanks for using FIX YA
Lost Over-drive????
time to consider a visit to the junk yard and fit a manual
Lost Over-drive????
I read your problem, and I think Reliable-Store has the solution of your problem, Just visit the link I attached here, I'm sure you will get the solution of your problem forsure. Best Manuals
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
